Tribeca light questions
Old Mar 12, 2016 | 03:33 PM
quickquest88's Avatar
quickquest88
Trifecta light questions
I have the infamous trifectia. I have replaced all four speed sensors, and they won't go out..
Next steps?
I have also noticed that when applying the brakes that I will get a short pulse of the abs system. Happens once each time I brake. If I let off, then get back on, it will happen again. Is this a normal symptom of the trifecta?
Old Mar 14, 2016 | 08:05 AM
Hello,
Did you clear the codes ?
You need to get a good scan tool and see which corner is bad or has a bad contact. This tool will find out which side, then you can diagnosis it better.
https://www.northamericanmotoring.co...tic-tools.html
You might have a bad plug socket at the connection and you need to know what corner. Rare the abs module needs replaced most of the time its the sensor on one corner , or the sensor installed cracked in the carrier.
https://www.northamericanmotoring.co...ed-sensor.html
The short pulse could be the system working then not working.
Old Mar 14, 2016 | 08:37 AM
jamez's Avatar
jamez
I'm going through a Trifecta at the moment as well...
Aided by the Schwaben scan tool... it located the sensor that was out
https://www.ecstuning.com/Search/Sit...699/ES2975699/
Just as the trifecta appeared once (mine is intermittent) my ABS did have a hissy-fit which shocked me. It hasn't happened since. I can't say I've heard of it triggering the ABS every time... hopefully others will weigh in.
Interestingly, the scan tool listed above does allow for activation/testing/bleeding of the ABS/DSC/ACS systems (down to the individual valve level) so it may be an advantage when you do get around to finding the problem and getting everything back in order if you end up replacing anything.
Doc Pain
Mar 14, 2016 09:01 AM
Cjarvis1136
Mar 13, 2016 05:47 AM
Price
Mar 12, 2016 03:03 PM
Tundrageek
Mar 12, 2016 10:55 AM
mharrell
Mar 10, 2016 02:23 PM
