Snapped Convertible Top Cable
Old Jan 6, 2016 | 10:01 AM
Akaki's Avatar
Akaki
Hi guys. A small piece of plastic snapped off of the driver's side convertible top when I was opening it one day. Didn't think too much of it and kept on my way. I did start to hear a significant amount of wind noise coming in from what sounded like the driver's side window. I tried snugging up the window and it didn't solve the problem. So when i got home I took a look at it and noticed that there was a cable sticking out of the top.
Small cable sticking out above the window.
There is the snapped cable.
Any idea on if this is fixable without replacing my entire top? I have seen some of the repair videos for the latch cables but I think this is farther back in the system. Thanks!
Old Jan 6, 2016 | 10:11 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Are you able to put your top down? The convertible top cables have been known to separate from the front of the base. Unfortunately, you have to buy both the convertible top cables as they come in a set HERE. I did find this thread on NAM here where an individual was selling the single cable for the drivers side, but it was a few months ago. Might see if he still has it. You can also try and post up a thread or do a search to see if someone else might be selling one of theirs.
888.280.7799 | 6am - 5pm PST
Old Jan 6, 2016 | 10:17 AM
Akaki's Avatar
Akaki
Thank you for the reply, but isn't that the part that this cable would connect to? I believe that the cable in my picture is the backside connection of the one you showed. The one in my picture is not wrapped in a spring like the one you linked. I could be wrong, but could you clarify?
Old Jan 6, 2016 | 10:57 AM
PelicanParts.com
Vendor
Correct, sorry wasn't looking closely. So it looks as if it is the left tensioner rope. It keeps the sides of the top snug, which is probably why you hear more noise now. Rope is HERE if needed, #11 on the diagram below. I would suggest tying fishing line to the old one before you pull it out to make it easier to get back in, a heavy test like 8-10 lb line would be good.
Old Jan 6, 2016 | 11:28 AM
I have the same thing in my R52 and fixed on the cable side, make sure the tabs on that side are in place ( mine bent, but did not break ) , they can get bent and then the tension rope pop out and busts the end , the cable connects under the fabric and pulls the top tight when the sunroof position is closed. 54347079877
But what you have is the cable just popped out and frayed the wire. The wire have a little plastic cover on the end and fits back into place. twist the wire back in place, put the top back a hair in sunroof potion and reinsert the cable just like the other side. Other wise you will need a new cable is anything is broken underneath.
As a R52 convertible owner I have worked on these many times.
Old Jan 8, 2016 | 09:01 PM
Akaki's Avatar
Akaki
Thanks! I did just that. Except I roughed up those metal tabs and added some JB Weld to it. That thing shouldn't come out anymore!
Re-inserted the rope into the bracket.
Added some JB Weld to make sure that it didn't come out. I even added some to the other side as a precautionary measure.
Old Jan 11, 2016 | 05:11 AM
You are welcome. Yea that's a quick fix, should hold now , That cable pulls very tigt and i think over years it works its way out. Mine did it on the same side also. The right side looks fine.
If you need anythings else for the Convertible , let me know. I also have a Hot Orange also, but with a blue top.
Old Jan 11, 2016 | 06:49 AM
DaGriz's Avatar
DaGriz
I need to keep you on speed dial for my R52.
What kind of lubrication do you use and where. Seems to be lots of points that could use some.
Old Jan 11, 2016 | 06:58 AM
yep. Kind of the Convertible MINI go to person here. 255K and going strong.
Sunroof grease, on the all sliders and cables. Just a tad. Clean any and add old grim off first and re-grease.
https://www.ecstuning.com/Search/SiteSearch/ES2194672/
Then wd 40 or any general spray lube lube on the pivot points of the metal frame on the convertible top.
Gummi Fledge on the rubber weather stripping.
Old Jan 12, 2016 | 11:44 AM
jgk6502's Avatar
jgk6502
+1 on the Einszett Gummi Pflege
I usually use WD40 as a solvent/cleaner. Something, like tri-flow might be better.
I didn't know about sunroof grease. Thanks for the tip
Old Jan 12, 2016 | 11:46 AM
Welcome.
Old Jul 12, 2017 | 02:48 PM
CaliforniaVegan's Avatar
CaliforniaVegan
cable came loose
Hi y'all. Here's a pic of my disaster. Can it be fixed?
Passenger side--the cable popped out of it's slot.
This is the driver side. You can see that there's no cable showing.
Old Jul 12, 2017 | 04:14 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Suggest you do some searches in this subforum, the Stock Problems/Issues and the DIY. I know there is a thread here on NAM where the cables broke and the guy fixed them with JB Weld or something. I have spotty internet as I am up in the hills on vacation otherwise I would find you the link.
Old Jul 12, 2017 | 04:25 PM
CaliforniaVegan
Ok, thanks. I'll look for it.
Old Jul 14, 2017 | 02:17 PM
Looks like It popped out of the tube or the tube broke, I will have to take a look at mine and check things out.
Old Jul 14, 2017 | 05:11 PM
CaliforniaVegan
Ok, thanks for checking into it. What do those cables do, anyway?
Old May 20, 2018 | 05:40 PM
Chammy's Avatar
Chammy
Tensioner rope
I am trying to replace the tension rope on my r52. But halfway down i found this.
Clamped down
Am i supposed to pry open the loop or am i supposed to bypass this?
The replacement part I am not sure how i am supposed to attach this. I cant feel a plate in there to remove. Any suggestions?
Old May 20, 2018 | 07:14 PM
CaliforniaVegan
Chammy, I am sorry to say I have no suggestions. I finally just had my top replaced altogether. :-(
Old May 20, 2018 | 07:58 PM
Chammy's Avatar
Chammy
Thats ok. I cant afford 5k to replace my top. Lol. I fixed the first issue. I used a screw driver to pry it open. But i couldn't figure out how to attach the plate. Im wondering if it is a redesign.? Also, now i see a link to a possible hardware kit.. Hopefully Mr. Guru will hop on and shed a little bit of light on this
Says tensioning belt?? Not ropes..
Install hardware ??
Old May 29, 2018 | 11:01 AM
The one end ( with no hardware) goes into the hole above and the other end mounts under the top fabric. The mounting kit which i dont have a pic of has the attachment hardware.
I have not gone through all the TIS info on the convertible, might be helpful to go through all this. I just know what it looks like and does on mr R52.
https://www.newtis.info/tisv2/a/en/r...roof-soft-top/
Old Jun 2, 2018 | 04:31 PM
jjcsnlynn's Avatar
jjcsnlynn
I like the idea of the grease. I didn't even think to lube the top...
Old Jun 11, 2018 | 01:35 PM
Yep, you dont want any hang ups on that line.
ignorante
14
Feb 11, 2016 09:27 AM
Bearybee
Dec 24, 2015 08:31 AM
Josh/AWE
Dec 14, 2015 12:52 PM
Josh/AWE
Dec 14, 2015 12:42 PM
AFN704
Dec 11, 2015 04:06 PM
