Unable to Read ECU
Old Sep 16, 2015 | 03:50 PM
JLSM511's Avatar
JLSM511
Unable to Read ECU
Hey guys,
I have an '04 R53 which has it's 'Service Engine Soon' light on and I am trying to read the code off the computer but am unable to get a connection with it. As a bit of history, at one point the car had the shift lights kit installed which crimp on to the harness that plugs into the OBD port. I have since removed this and I suspect that may be the issue. When I plug in an OBD Reader, it turns on and starts reading but either fails or loses power and gets it back after a few seconds. Is there any way to fix this? Can I solder new cables to the OBD plug? Whats the best way to tackle this?
Thanks!
Old Feb 22, 2016 | 02:41 PM
tom strange's Avatar
tom strange
any help?
Hi,
Just wondering if you ever learned anything on this. I have a similar problem on an 02 R50. No connection to the car when plugged into the obd2 port ...
Did you ever find anything to help with your problem???? different car, but your fix may be helpful.
Thanks in advance,
Tom
Old Feb 25, 2016 | 01:02 PM
You would have to inspect that wires and make sure there is a complete circuit to the plug.
. Some OBD 2 tool have a hard time of connecting my actron unit did this, took like 3-4 times. . But the schwaben unit did not have issue. When you use it the ignition has to be turned on without the engine running, so key in position 1 . Some readers dont like to read at all..
https://www.ecstuning.com/Search/SiteSearch/ES2975699/
Rainforest_Elf
Sep 15, 2015 12:11 PM
potterstein
Sep 13, 2015 09:57 PM
ShadyCoop
Sep 11, 2015 11:14 AM
