what is this part? HELP!!!
Old Aug 9, 2015 | 11:29 AM
Lt. Dan's Avatar
Lt. Dan
I did intake boots last night, and a new crank pulley with new belt. After re-assembly, the car will start, but shut off immediately. If I give it gas, it'll run, but not well. After I disconnected both vacuum lines from this, vehicle will now start and idle. After it's running, I can hook both lines back up, and it will continue to run fine, but if I shut if off, I have to repeat the process. Nice theft deterrent, but I'd prefer the traditional way of starting the car by "turning the key and go"... So I'm I'm thinking I probably whacked this thing with the belt tool and damaged it... So- What the F*&K is it, so I can get a new one!!!! LOL....
Old Aug 9, 2015 | 02:14 PM
Lt. Dan's Avatar
Lt. Dan
In case anybody else is looking- It's the Purge solenoid valve.
Old Aug 10, 2015 | 12:46 PM
Yep, 13907572086 MINI part #
Just talked about it, glad you figured it out .
https://www.northamericanmotoring.co...-long-way.html
bobbiemartin
Jan 20, 2016 05:28 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
Ryephile
Aug 25, 2015 06:51 AM
nomar116
Aug 21, 2015 04:36 PM
