Oil Filter
Old Aug 3, 2004 | 08:25 AM
mountainrider's Avatar
mountainrider
Oil Filter
What brand oil filter can you use besides the Mini filter?
Thanks William
Old Aug 3, 2004 | 08:29 AM
Ryephile's Avatar
Ryephile
I'd also like to know if there are any others besides OEM
Old Aug 3, 2004 | 08:45 AM
LilRedMini's Avatar
LilRedMini
Purolator offers one and I think they are the OEM. They cost $10 though.
You can get a factory filter from Classic Auto Campus (click on sponser directory) for $6. I ordered a half dozen from them when ordering some other parts.
They are a VERY good parts source. They are friendly, prompt, reliable and best of all, they have great prices. I am not affiliated, only a satisfied customer.
Old Aug 3, 2004 | 09:49 AM
mountainrider
I thought the Cooper used some sort of micron oil filter.Looks like it would need one to go 10000 between oil changes.
Old Aug 3, 2004 | 11:39 AM
polmear's Avatar
polmear
Mahle makes an AM filter. I believe they also make the OE filter.
Old Aug 3, 2004 | 11:47 AM
2minis's Avatar
2minis
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
These folks are in Albuquerque. Good deal.
Old Aug 3, 2004 | 01:24 PM
mountainrider
Wix part number 57303
Old Aug 3, 2004 | 01:31 PM
05JCWS's Avatar
05JCWS
Mountainraider,
If I were you I would just buy them from Classic Campus, and get the OEM filter. $6 for a filter, you really can't go wrong. And if you are trying to save another $1 or $2, you are saving it in the wrong place.
Old Aug 3, 2004 | 04:01 PM
mountainrider
Originally Posted by dgszweda1
Mountainraider,
I am not looking for cheap.Just thought someone would have a better filter.
Old Aug 7, 2004 | 06:14 PM
retroom's Avatar
retroom
Speaking about the oil filter... has anyone not been able to unscrew the canister because the dealer installed to tight after an oil change?? This has happened to me twice... and to top it off I can't unscrew the oil drain plug it's over-torqued too!! I guess I'll have to take it back so they can loosen both.
retroom
Old Aug 7, 2004 | 06:33 PM
goldcountrymini's Avatar
goldcountrymini
This has been super helpful information. Thanks. I need to pick up a few oil filters.
Speaking of which, what type of oil is everyone using?
Old Aug 7, 2004 | 07:36 PM
paddy's Avatar
paddy
Did I miss something in the ebay auction???? How many filters did the winning bid get for $24.95?????? I hope more than 4, I only pay $6.75 for the OEM filter at the dealer! ! ! ! ! I think I have found a place on line that is selling them for $4.75, OEM or Maham(sp) or something like that.
As for oil Mobile 1, 5w30 - Walmart $21 for a 5qt jug. :smile:
Old Aug 7, 2004 | 07:50 PM
LilOleCar's Avatar
LilOleCar
retroom
That happened to me; after my first oil change, I did the second myself. The oil filter cannister, which is supposed to be somewhere around 12Nm, was cranked up to at least 80 or 90Nm. I am not impressed with Global Imports Mini. The people there are good with customer relations (mostly), but the techs.... not sure about those guys.
-Cor.
Old Aug 8, 2004 | 10:17 AM
apexer's Avatar
apexer
I've been using Redlaine 5W30. IMHO its the best on the market... no cheap... but execllent if your planning on extended change intervals ie: every 10K miles.
Old Aug 8, 2004 | 11:51 AM
LilRedMini's Avatar
LilRedMini
A note about those extended oil change intervals. In engines with timing chains such as our mini's, an extended interval REGARDLESS of oil used, has long term consequences.
Extending the interval allows microscopic grit to accumulate in the oil. For the most part, this small volume of microscopic grit does no harm EXCEPT for the timing chain. This grit will cause premature wear in the links, pins and sideplates of the timing chain.
To me, the fact that these cars have a timing chain rather than a belt is a HUGE advantage. Belts must be changed regularly and typically are a serious PAIN to change in small cars with cramped engine compartments. The fact that the MINI has a chain was a HUGE deciding factor for me in selecting the MINI.
Extending the oil change intervals too much will allow timing chain wear that is typically called "stretch." The metal parts don't stretch, but the small amount of wire in all links adds up to allow the chain to become longer, causing valve timing inaccuracy.
If this were a belted timing engine, long intervals could be very workable and still allow long engine life. If you are willing to replace the chain at 100,000 miles or so, then extended intervals could be workable, but do the math. Changing the chain and components, I would guess would be in the $500 range done by a shop. So how many extra oil changes can you do for $500?
Old Aug 8, 2004 | 04:43 PM
JoeDentist's Avatar
JoeDentist
I just went into an Advance Auto and they had a Purolater Premium Plus filter # L15465 sitting right on the shelf. Interesting, since there is no Mini dealer in town and no Mini's for that matter. These things are obviously not difficult to find. Must fit something else as well.
Old Aug 9, 2004 | 03:58 AM
LilRedMini's Avatar
LilRedMini
It's really funny to see what is and is not stocked in some stores. JoeDentist finds the correct filter in a store, in a town where he has the only MINI. Before I bought a half dozen from Classic Campus, I went into a Purolator stocking store in Plano, Texas where there is a reasonable number of MINI's and they didn't even have a slot on the shelf for that number.
The engine plant in Brazil was built as a joint venture having to do with Chrysler. At least that is what I read somewhere. Is it being used in any other car besides the MINI?
Old Aug 9, 2004 | 05:38 PM
JustGo4It_'s Avatar
JustGo4It_
I believe the 1.6 supercharged motor is specific to the Cooper S
The standard 1.6:
A 16-valve, in-line 4-cylinder power plant delivering 114 bhp at 6,000 rpm. Variants of the 1.6L engine power the BMW Mini (Mini One & Mini Cooper models) assembled in England, the DaimlerChrysler PT Cruiser assembled in Mexico and the Chevy A15 assembledin China.
http://www.tritecmotors.com.br/english/motors/16L.htm
Old Aug 10, 2004 | 06:32 AM
LilRedMini's Avatar
LilRedMini
Thanks for the info. So now I know that if I need MINI engine parts I can go to my friendly, neighborhood Dodge dealer. The oil filter probably interchanges with the PT Cruiser.
Old Aug 12, 2004 | 06:26 PM
retroom's Avatar
retroom
-Cor.
I finally took my car to the dealer to loosen the oil filter canister and oil drain plug. The mechanic says the canister should be tightned to 25Nm. He had to put my car on the lift to loosen the oil drain plug. I'll change the oil and filter this weekend.
I also asked him about the extended oil change interval and he said he doesn't see a problem with it, however, their dealership will change the oil ever 12 months regardless of mileage.
retroom
Old Aug 28, 2004 | 08:19 AM
Splicer's Avatar
Splicer
Purolator L15465
I have posted this before, but here it is again.
IF you have am "S" don't use the Purolator filter. It does not have, (Or didn't) the plastic support cage internally. This will cause the following to happen.
http://img.photobucket.com/albums/v1...er65/Puro2.jpg
The Purolator was intended for the early Base MINI only with the spring loaded canister. This from my conversations with Purolator.
In any aftermarket, check for the internal support!
Paul
Old Aug 30, 2004 | 09:20 AM
bradman's Avatar
bradman
The Purolator filter works fine as long as you make sure to use the spring-loaded plastic support cage that comes as part of the aluminum canister. (The BMW OEM filters have an additional, somewhat less robust, plastic cage built into them for redundancy.) I have used the Puroilator filters in two oil changes thus far and have had no problems. I think that the problems that some people have had with the Purolator filter is that they did not use the spring loaded plastic cage. I know that when I did the first oil change (at 100 miles...yes, you heard me...man, was the factory oil dark!) the filter was really stuck in the canister, and when I pried it out it pulled the spring-loaded plastic cage out of the aluminum canister. I pulled the plastic cage out of the old filter and secured it back in place in the canister (it snaps back into place) before installing the new (Purolator) filter over it. All of this rasises a question, though. I wonder how many people may have inadvertently tossed out the permanent plastic cage mounted in the canister when they pulled out the oil filter? From Splicer's oil filter pic it looks like it collapsed because it had no internal support (i.e., the plastic cage attached to the canister).
Old Aug 30, 2004 | 12:57 PM
Splicer's Avatar
Splicer
Internal Cage
<The Purolator filter works fine as long as you make sure to use the spring-loaded plastic support cage that comes as part of the aluminum canister.>
It is worth noting here that the removable, spring loaded, plastic cage is NOT on every MINI. Thru previous discussion here and with Purolator, it has been determined that many "S" models do not have it. This assembly is the Bypass valve, and on many "S" from late '02 onward, this function/assembly is in the Block and not the canister. In fact , when the filter is removed the canister is empty. In discussion with my dealer, they carry only one filter, use it on both, and it does have the internal cage, therefore eliminating any potential problems for them. If you search the various how-to MINI pages you can find examples and pictures of both.
Kimolaoha
Jul 5, 2023 01:04 PM
devicemanager
Jun 17, 2016 06:18 PM
Chasp
Aug 25, 2015 06:44 PM
Chasp
Aug 22, 2015 01:26 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
