What's wrong with my poor mini
Old Jun 11, 2015 | 10:53 AM
Phreshprince's Avatar
Phreshprince
I had my car idling and went back out to it. I was on a hill trying to take off then all of a sudden it started hopping when I was letting the clutch out. It died and I tried started it back and heard a squeaking noise. I turned it off and coasted into a parking spot. Popped and the hood and saw steam coming from the back right side and smelled burned brake fluid type smell. Pressed my clutch in and it went in about 1/8th in and stopped like something was behind it. Then finally it popped lose and went to the floor with no resistance. Let off the pedal did the samething. I poured slave cyclinder fluid in (DOT 4) into the reservoir because it was empty. Started pumping the clutch and the stiffness left but still was normal resistance like it usually is. I started the car, squealing happened, I pumped the clutch and tried to put it into first but nothing. The clutch pedal wants to stay at the bottom after pressing it in. Slave cyclinder bad, throw out bearing shot, bad pressure plate, clutch master cyclinder **** on me, or clutch go completely out? Someone please help!!!
Old Jun 11, 2015 | 11:03 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I'm thinking possibly the slave cylinder... Maybe someone else will have a different suggestion. Typically, a spongy feel to the clutch pedal, grinding of gears when shifting, long pedal travel, and hydraulic leaks under the car are all signs that one or more components of the system have failed. The first place I like to start is the clutch slave cylinder, as it is easy to replace. You can read more about the system and how to replace it here. As far as the clutch, was there any sign that it was on its way out possibly? Slipping and or engagement issues? Can read up on the clutch replacement here.
Here is what sounds like a somewhat similar issue in this thread here.
If you need parts for this job, you can get them in our catalog here. Let me know if you have any other questions or need any other assistance.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 11, 2015 | 11:07 AM
Phreshprince
The has never given me any issues. No, slipping or anything. This just happened suddenly. I just got done driving in stop and go traffic drove the interstate for an hour ran into a store and went to take off the it just stopped.
Old Jun 11, 2015 | 11:26 AM
Its sound like the slave cylinder that leaks and then goes, check for the fluid leak, it will leak into the transmission housing and then leak around the connection to the housing. Do you have any fluid on the floor ? Should be on the driver side in front of the transmission. Two bolts to hold it on and then replace it and the new fluid, they can be a paint to re-bleed.
Whats year and model do you have ?
Old Jun 11, 2015 | 11:29 AM
Phreshprince
06 mini S. The reservoir was empty and I filled it up. It could have leaked while I was in stop and go traffic and finally got empty and went out
Old Jun 11, 2015 | 11:38 AM
PelicanParts.com
Vendor
Then I'd start with the slave cylinder. It's the easiest thing to replace right now and might be the culprit. Can buy a slave cylinder here if need be and I posted a good DIY replacement in my first post. Good luck!
-Luccia
Old Jun 11, 2015 | 11:40 AM
Phreshprince
Going to order slave cyclinder when I get paid along with, full exhaust, 19% pulley, lowering springs, intake, and plasti dip kit. I'm hoping it's the slave cyclinder or clutch master cyclinder.
Old Jun 11, 2015 | 11:42 AM
Yes , take a look at the slave cylinder, under the engine / on the transmission right in front of the driver side. Look for fluid all around and on the bell housing of the transmission.
Mfg Part# 21516777428
http://www.ecstuning.com/Mini-2006-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Drivetrain/Clutch/3
Then get some new DOT 4 fluid for replacement .
On bleeding good tips here:
https://www.northamericanmotoring.co...-cylinder.html
PelicanParts.com
Vendor
Sounds like a lot of fun upgrades! Be sure to check out what we offer in our parts catalog here. Definitely let me know if that resolves your issue and if you have any other questions that I can answer. Cheers.
-Luccia
Old Jun 11, 2015 | 11:45 AM
Phreshprince
Is it hard to change slave cyclinder?
Old Jun 11, 2015 | 11:47 AM
PelicanParts.com
Vendor
Replacement of the slave cylinder on the MINI is a snap. Its location is easy to get to from underneath the car. Look at this link here, which provides a step by step process of replacing it yourself.
-Luccia
Old Jun 11, 2015 | 11:48 AM
Phreshprince
Thank you. I'm hoping it is just the slave cyclinder so I can order the fun stuff >:D
Its a little bit of a job , other then two bolts and a disconnect , the bleeding is the a bit hard part, check that thread I linked.
Old Jun 11, 2015 | 11:50 AM
PelicanParts.com
Vendor
You're very welcome! Yes, I hope it is too. Enjoy the fun stuff.
-Luccia
Old Jun 11, 2015 | 11:58 AM
The bleeding will take you a couple time. Please inspect the area under the transmission to rule out there is not a corroded line or something else. Then get the slave cylinder.
Good luck and hope you can get it fixed.
Old Jun 11, 2015 | 09:59 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Since you lost fluid you must have a leak of some sort. The Slave cylinder is by far the most common to leak.
But with the other description you have of the feel and sound be prepared for more at those are not normal for just a slave failure.
Old Jun 12, 2015 | 11:10 AM
Phreshprince
Well, I'm gonna need a whole clutch kit not a slave cyclinder. My mechanic friends even said so. Now what's a good clutch to go with without emptying my piggy bank?
Old Jun 12, 2015 | 12:01 PM
Did you looks at the slave cylinder ? Or just think you burn the clutch , even when burn it would not go to the floor unless you damaged the pressure plate into the throw out bearing ?
For a clutch kit I would go with the Valeo / dual mass to single mass conversion.
Best cost option. And you will not have to replace that expensive dual mass flywheel , its replaced with the conversion kit.
Old Jun 12, 2015 | 12:21 PM
PelicanParts.com
Vendor
Sorry to hear! Did he inspect the vehicle?
If you're wanting to stick with OEM and not performance, I would recommend this one, 21-20-7-551-384-M37. Or you can stick with genuine MINI, which is listed below it here.
To save money, here is a DIY replacement.
-Luccia
Old Jun 12, 2015 | 12:22 PM
Phreshprince
It's squealing really bad and lightens up some when I hit the clutch. It's never been replaced I don't believe
Old Jun 12, 2015 | 12:39 PM
The valeo dual mass to single mass kit is the best for cost. If you go with Genuine MINI we have linked the dual mass itself is a pretty penny.
Just wanted to let you know.
Good luck and glad I could help.
Old Jun 12, 2015 | 12:48 PM
chappybmode's Avatar
chappybmode
The squealing is probably your throwout bearing. The other issues sound like a slave cylinder. I have never heard of one going so quickly though without notice.
Old Jun 12, 2015 | 01:06 PM
PelicanParts.com
Vendor
Hm, ya might just need to replace it all and leave it at that. Best to fix it all and not have anymore issues with it.
-Luccia
Motown
Apr 20, 2018 09:31 AM
arf88
May 31, 2016 03:07 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
Dashdog
Aug 10, 2015 06:17 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
