Hit a really bad bump and now my mini shuts off at every bump
Old Apr 7, 2015 | 06:03 AM
daonlyillwiz's Avatar
daonlyillwiz
I read online that this could be a fuel pump inertia switch but i have a 2005 mini cooper s (r53) and from my understanding they stopped using these in 2002. Any idea how i can reset this switch?
Old Apr 7, 2015 | 06:10 AM
daonlyillwiz
In addition to this the mini will not shut off and remain off it will just cut off and come back on, the check engine light and EML will come on then dissappear and the TPMS + DSC lights will stay on
Old Apr 7, 2015 | 09:40 AM
daonlyillwiz
Anyone
Old Apr 7, 2015 | 10:12 AM
JABowders's Avatar
JABowders
Veteran: Army
Sounds more like a loose relay or a touchy fuse... if it was the fuel pump inertia switch (look here)
https://www.northamericanmotoring.co...ct-switch.html
These can be found on R50, R52, and the R53 W11 engines
Hope this helps...
Motor on!
Old Apr 7, 2015 | 10:22 AM
daonlyillwiz
I came across that thread but i have an 05 r53 and according to that thread in 04 they made it part of the airbag module
Old Apr 7, 2015 | 10:32 AM
daonlyillwiz
boom found the culprit...loose engine relay
Old Jul 12, 2024 | 06:24 PM
nitschke30's Avatar
nitschke30
Same issue
Hey man, I have the same exact issue and symptoms as you!! Going to try swapping the relay and see if it works- just wanted to say thank you as if its the issue it’ll save me a LOT of time.
wind715
Aug 11, 2015 07:56 AM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
Lt. Dan
Aug 10, 2015 12:46 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
tippin
Aug 5, 2015 08:43 AM
