Car stalled while driving
Old Feb 26, 2015 | 04:01 PM
hong's Avatar
hong
Hi, I noticed that recently my 2006 MCS stalled which driving, for no apparent reasons, some details:
When It happened, car appeared to gradually lose momentum, followed by the “EML” light and “Check Engine Soon” light, then started to shake, as the engine rotation slowed down.
It happened for no apparent reason, I did notice that it seemed to happen more frequently when I did fast acceleration.
After I pulled over, stopped the engine, waited for a little while, it then restarted and drove normally, as if nothing has happened.
I had an ODB scaner connected all the time, but it didn’t return any error code.
It happened more on local road, and rarely occurred on highway.
Most of time it could drive normally for quite some days, even months.
It has been through some repairs, most recently the body shop replaced the throttle housing assembly. It also had new belt, spark plugs, etc.
What would be next steps to troubleshoot this issue?
Old Feb 26, 2015 | 07:21 PM
TheSkyIsUp's Avatar
TheSkyIsUp
My friends jeep did this often, and I had a Passat that did this aswell, both for different reasons.
Now, in no way are they similar to a MINI, but some quick checks might help.
The passat would stall out because the air filter hosing was loose, so if it became undone it would slow down and stall out in whatever gear.
The jeep had a very dirty fuel filter, that was preventing it getting fuel and would stall out if he got the RPMs low enough.
Goodluck on the issue though!
Old Feb 26, 2015 | 09:06 PM
devenh's Avatar
devenh
I've run into a similar issue. Take the car into the shop and have them read the scan code. In my case there was a throttle body error, but the system now tests fine.
Old Feb 27, 2015 | 02:05 PM
ottawa's Avatar
ottawa
Was it code p1125 and or p1126?
If so, it's either your throttle body or the wiring harness to the tb.
Old Feb 28, 2015 | 02:01 PM
devenh's Avatar
devenh
Actually P1685. See:
https://www.northamericanmotoring.co...ng-lights.html
Wohnson89
Jun 10, 2020 04:53 AM
xpunisherx
Aug 10, 2015 10:50 PM
ludedude
Aug 10, 2015 07:16 PM
PatrikKN
Aug 5, 2015 09:10 PM
