Water leak driver side engine identification. R53
Old Feb 1, 2015 | 12:27 PM
GPToyz's Avatar
GPToyz
So I have been trying to chance down this water/coolant leak.
It's on the left side of my engine head. I can see the water bubbling out and it's pooling. Near the intake arm to the air box
I can't upload the picture I took at the moment because of this crappy IB app interface.
I think it's not the head gasket because water/oil are not mixing.
Im not leaking oil thank god either.
Old Feb 1, 2015 | 01:30 PM
GPToyz's Avatar
GPToyz
Finally got it attached
Old Feb 1, 2015 | 05:08 PM
elchilo4ever's Avatar
elchilo4ever
Is really easy to change the gasket
Only 3 10mm screws to remove it.
But Check Well because maybe the cover
Can be cracked....
Also I recommend to put new thermostat.
I Installed N' My Mini The M7 Thermostat
The M7 is 180F & The Original is 195F
Old Feb 7, 2015 | 11:40 PM
Debi's Coop S's Avatar
Debi's Coop S
Definitely your thermostat housing. Recommend replace thermostat with new gasket.
bobbiemartin
Jan 20, 2016 05:28 PM
maestro39
Oct 27, 2015 02:38 PM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
