coolant leak
Old Dec 22, 2014 | 01:47 PM
pocketmaster's Avatar
pocketmaster
coolant leak
My son's 05 Mini s has a coolant leak. It's pooling in an area just below the positive battery jump port. The attached pic shows the location of the leak. Could this be simply bad hose clamps??
Old Dec 22, 2014 | 06:19 PM
Kahnfucious's Avatar
Kahnfucious
Most common leak on the cooper S is the overflow tank...splits at the seam. Pull back in your picture. How many miles?
Old Dec 22, 2014 | 06:24 PM
pocketmaster
Thanks for the reply. I did some digging and noticed the thermostat housing was leaking around the lower bolt. Pulled the housing off and the gasket pretty much fell apart. I'm hoping this was the cause. I'll know for sure after I get the new gasket tomorrow.
Old Dec 22, 2014 | 06:29 PM
Kahnfucious
Yup that is also a very common leak. If the gasket is toast then pretty good chance that as the issue. Good luck
Old Dec 22, 2014 | 07:11 PM
ZippyNH's Avatar
ZippyNH
The gasket is molded into the thermostat...so I suggest you replace the thermostat.
A few places have tried to sell replacements, but they simply don't work...
Most every mini thermostat gasket ever made failed...and mini has revised the part...Newer ones seem to work fine.
The next most common issue is the tank mentioned... They get pinholes in the glued seam..if it has any residue around the seam, replace it.
Old Dec 22, 2014 | 08:30 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Pretty common failure. We replace one a week in the shop here.
http://www.waymotorworks.com/thermos...t-r50-r53.html
It's not a bad idea to go ahead and replace the housing too since they are pretty old.
http://www.waymotorworks.com/r53-the...t-housing.html
Old Dec 23, 2014 | 06:06 AM
buzzsaw's Avatar
buzzsaw
Have read on many sites that keeping the fluid level below the seam in the coolant tank helps longevity.
shorenetworks
Nov 4, 2019 06:18 PM
debitsandcredits
Sep 21, 2015 08:34 AM
rikaro
Sep 21, 2015 06:57 AM
olson187
Sep 18, 2015 10:26 AM
mimaal
Sep 4, 2015 09:09 AM
