2006 S: what is this engine bolt? + cracks?
Old Dec 16, 2014 | 10:05 PM
billie_morini's Avatar
billie_morini
My 2006 S started leaking motor oil. Inspection suggests oil leaks from a specific 10mm bolt on engine's bottom. There is blue factory paint dot adjacent to it. What is this bolt for (photo)?
The housing appears scraped (photo). Is it cracked, too (photo)? I see raised aluminum flecks, lines, and, possibly, poor milling that make me think it is a poor casting. Some lines look more like cracks. What does your engine housing or casing look like?
Am concerned. Only have my own Mini to look at for comparison.
Attached Thumbnails 2006 S: what is this engine bolt? + cracks?-bolt_location.jpg   2006 S: what is this engine bolt? + cracks?-bolt_area_detail_01.jpg   2006 S: what is this engine bolt? + cracks?-bolt_area_detail_02.jpg
Old Dec 16, 2014 | 11:36 PM
Thatguy198484's Avatar
Thatguy198484
Should just be oil pan gasket .... And no it doesn't look cracked all r53 oil pans are like that
Old Dec 17, 2014 | 05:08 AM
Saltysalt's Avatar
Saltysalt
its most likely a silver lined paint to help with pitting and corrosion. haven't seen leaking from a bolt, usually the gasket fails =)
Old Dec 17, 2014 | 07:05 AM
jamez's Avatar
jamez
My money says your rear main seal is toast. Oil is leaking into the bell housing and finding that place to exit (it's the lowest point and there's no gasket between the engine and bell housing).
Be aware that if left, it can kill your clutch.
If you're replacing the clutch, you should also change the rear main seal.
Old Dec 17, 2014 | 10:34 AM
socalr53's Avatar
socalr53
Originally Posted by jamez
my money says your rear main seal is toast. Oil is leaking into the bell housing and finding that place to exit (it's the lowest point and there's no gasket between the engine and bell housing).
+1
Old Dec 17, 2014 | 11:01 AM
socalr53's Avatar
socalr53
I crawled under the car this morning to find out about a small leak ( few drops) noticed on the floor, took some pictures. The leak in my car is not same as yours though. but one picture shows the housing. hope this helps. sorry for the picture quality.
I heard too much motor oil can cause the rear main to leak as well
how many miles on your car ?
Attached Thumbnails 2006 S: what is this engine bolt? + cracks?-img_0503.jpg   2006 S: what is this engine bolt? + cracks?-img_0504.jpg   2006 S: what is this engine bolt? + cracks?-img_0499.jpg
Old Dec 17, 2014 | 11:44 AM
jamez's Avatar
jamez
socalr53
I can't get my mind wrapped around your images. Try uploading larger ones and orient them or mark them with reference points - front - PS fan etc (is it an auto transmission?)
OP - I forgot to mention that your casing looks like mine. Don't worry about that - just the leak.
Old Dec 17, 2014 | 08:38 PM
billie_morini
The responses to my questions demonstrates why North American Motoring is the best website for automobile stuff. Thanks to all of you providing assistance.
Answer to mileage question: Approximately 82,000 miles; predominantly highway miles
Answer to transmission question: it is a manual transmission
Suggestions that engine's rear main seal may be leaking: good idea, will look into this. Agree, change main seal when changing clutch (not doing clutch replacement at moment, but maybe it's not far away due to this leak)
Corroborations that oil pans look like this: this is a big relief. Was a little freaked out
Old Dec 18, 2014 | 05:37 AM
jamez's Avatar
jamez
Just to make y'all feel better here's an old photo of mine (also showing the 'texture' of the oil pan and leak. Showing that I know what you're going through.
This what a rear main seal failure (and other leaks) can look like
Old Dec 18, 2014 | 09:56 AM
ashchuckton's Avatar
ashchuckton
This leak could also be from the input shaft seal on the transmission. You might want to check the transmission oil level for peace of mind. Running it low on oil will kill it.
Old Dec 18, 2014 | 08:17 PM
billie_morini
jamez, thank you for sharing the large annotated photo. It is helpful.
ashchuckton, thank you for a good idea to check the transmission fluid level.
SosoMINI
Nov 22, 2015 03:17 PM
Aug 19, 2015 12:51 PM
Powershift
Aug 16, 2015 05:14 PM
minipopkart
Aug 13, 2015 05:22 AM
FatherG
Aug 4, 2015 03:44 PM
