Clutches don't normally just stop working do they?
Old Dec 3, 2014 | 06:37 PM
traildog's Avatar
traildog
My son's 2004 r53 won't shift (I haven't actually tried it yet, it's stuck at his GF's).
He says the pedal has no resistance,, but, it wasn't making any noise.
Is there something that can become disconnected?
Old Dec 3, 2014 | 07:03 PM
ZippyNH's Avatar
ZippyNH
Clutch activation is hydrolytic... So a failed master or slave would make sense, assuming you can shift OK with the motor off.
Old Dec 3, 2014 | 07:34 PM
traildog's Avatar
traildog
Thanks zippy. Although I think I may have figured out the drops on the garage floor.
I always thought it was motor oil. Now, I'm thinking it's brake fluid.
Old Dec 4, 2014 | 05:22 AM
ZippyNH's Avatar
ZippyNH
Yup...uses dot4 from the same resiviour as the brake's...
So a leaky cylindar would make sense...
Old Dec 4, 2014 | 05:25 AM
traildog's Avatar
traildog
I sure hope that's all it is. I stuck my finger in one of the spots on the floor and gave it a sniff.
No smell.
Old Dec 4, 2014 | 05:49 AM
JABowders's Avatar
JABowders
Veteran: Army
+1 on more than likely the Slave Cylinder and/or Clutch Line, the connector is an ABS Plastic to ABS Plastic connector with an O-Ring held in with a Spring Clip.
You might be able to just TOP OFF your Brake Reservoir pump up your clutch pedal to get it home to work on it.
Best of luck.
Motor on!
Old Dec 4, 2014 | 02:38 PM
traildog's Avatar
traildog
Well, the fluid was definitely low. I got it to shift and brought it home.
Shifting got better and better the more I drove it, but, it's not shifting as smoothly as before.
I'm guessing it needs to be bled. Is that a big deal?
Old Dec 4, 2014 | 02:43 PM
cristo's Avatar
cristo
Alliance Member
First replace the leaking part, then bleed.
Bleeding is a bit tricky to get all the air out.
Usually have to remove and compress the transmission side slave cylinder to do it properly.
Do a search on it or get someone who knows how.
Old Dec 4, 2014 | 02:56 PM
traildog's Avatar
traildog
Double post (sort of)
Old Dec 4, 2014 | 02:59 PM
traildog's Avatar
traildog
I may or may not attempt it. I will find the leak first.
York, PA huh? Mom grew up on 941 North Duke Street!
Old Dec 4, 2014 | 04:51 PM
traildog's Avatar
traildog
Wow! YouTube is my friend! Looks like a really easy job.
I'll be making the tool to compress the slave cylinder.
I'll let you know how it goes.....
Old Dec 4, 2014 | 06:40 PM
cristo's Avatar
cristo
Alliance Member
That's just a couple dozen blocks north of me.
Old Dec 4, 2014 | 07:17 PM
traildog's Avatar
traildog
Truly a small world...........
Old Dec 5, 2014 | 04:02 PM
traildog's Avatar
traildog
Well, I guess I need a new slave cylinder. Got her bled out, but, I still have to double pump the clutch to get it to shift.
I may bleed it again just in case........
Old Dec 5, 2014 | 05:16 PM
ZippyNH's Avatar
ZippyNH
I'd just change it...
It should be sealed, and never need to be bleed once installed..and a puddle of dot4 on the floor is it dying cry for help!!
Old Dec 6, 2014 | 03:14 PM
traildog's Avatar
traildog
Well, I changed it and all is well again............
Thanks for the help fellas.
silence2-38554
Nov 12, 2015 09:39 AM
maestro39
Oct 27, 2015 02:38 PM
mini yellow-haa!
Aug 13, 2015 11:18 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
