What is the risk derived from spilling coolant on the serpentine belt?
Hi guys,
The long story short: I've bled my cooling system and, accidentally, I've spilled some coolant over the alternator and the serpentine belt.
My car is a Mini R50, 2005.
Now the issue is that, when starting the engine, there is a strange noise (like a whistling or something similar with a rather high pitch) coming form the alternator/serpentine belt area, which goes off only when I shut the engine off.
What do you think guys: is there a risk running the car like that?
Can the coolant damage the alternator or the rolls/belt?
Any input on this is more than welcome.
Thanks in advance!
Thanks in advance!
As added piece of mind you can always flush the area with some clean water, a liberal amount of water from a hose (no pressure) over the area to rise off the Alternator and belt should help.
Let air dry and test it out...
Motor on!
Motor on!
Sc00terbum
Sep 11, 2015 09:07 AM
