R53 oil leak on delivery from used dealer
Old May 1, 2014 | 08:23 PM
K9MINI's Avatar
K9MINI
So I just got my MC40 R53 with only 24k on the clock shipped up from FL and I have a major oil leak. The dealer did an oil change and from what I can see the oil leak is coming from around the oil filter housing. Much worse when car is running. Anyone have any ideas? Its not coming from the oil pan at all.
Attached Thumbnails R53 oil leak on delivery from used dealer-img_3371.jpg   R53 oil leak on delivery from used dealer-img_3373.jpg
Old May 1, 2014 | 08:36 PM
ottawa's Avatar
ottawa
I'd say don't run it and tighten the oil filter housing. I bet they did a pass poor job installing the filter which made the housing not sit 100%. Or depending on warrenty. Just drive it to dealer and fry engine and get a new one.
Old May 1, 2014 | 08:41 PM
ZippyNH's Avatar
ZippyNH
Bet the o-ring on the filter cap is split....VERY easy to do...even dealers, etc can do it....a new ones comes with a filter...you lube it..and put it in the slot in the cap..then tighten...they sometimes get caught...and tear...results is a leak...
Old May 2, 2014 | 04:40 AM
K9MINI's Avatar
K9MINI
Ok thanks guys. I had the car shipped up from FL.
Old May 2, 2014 | 05:50 AM
K9MINI's Avatar
K9MINI
Just took the MC into the dealer for an oil change. I am going to keep my fingers crossed and hope that the oring was split and we are good after that.
Will update you guys
Old May 2, 2014 | 07:12 AM
Yea +1 on the split o-ring on the filter. They might have not lubed it on the outside, went to put on the filter cap with the filter and walked the rubber gasket out and cut it. You might be able to put your hand down there and feel the seam, bet there is a piece of the gasket hanging out. #4
Oil Filter Kit With O-Ring Part # 11427512446
http://www.ecstuning.com/Search/SiteSearch/ES24009_ES257649/
BTW the MC40 looks awesome. What a time warp.
Old May 2, 2014 | 08:09 AM
K9MINI's Avatar
K9MINI
Thanks guys. It was in fact a split gasket. Dealer I purchased from is covering the tab so I am happy.
danielbrookes_9
Oct 3, 2015 12:51 PM
elightbo
Aug 17, 2015 01:50 PM
Lex2008
Aug 16, 2015 08:33 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
