p1705 Transmission Control Module LED Output Open Circuit
Old Apr 14, 2014 | 11:22 AM
Jose Garcia's Avatar
Jose Garcia
Anybody run into this? Anyone know what it means? I think it has to do with the LED indicators.Transmission Control Module LED Output Open Circuit
P1705 Transmission Control Module LED Output Open Circuit
Old Jul 15, 2018 | 05:19 PM
Docsigns's Avatar
Docsigns
I just got the code as well I look in to it, but from my understanding theres a wire grounding out.
Old Jul 15, 2018 | 05:23 PM
Docsigns's Avatar
Docsigns
P1705
LED Drives Plausibility Conditions:
Key on or engine running; and the DME detected an implausible signal (fault performed by the Gearbox Interface Box).The battery voltage is greater than 9 volts and the CAN Bus is operational.
Possible Causes:
• Short to battery
• Short to ground
• Open circuit
• CAN data bus wires have short circuited to each other
• ECU has failed
• BUS system failure
• Defective bus controller (EGS)
caiken
Aug 27, 2015 06:55 AM
Marktheman
Aug 23, 2015 11:45 AM
skippermini
Aug 13, 2015 06:13 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
