Feb/2002 Strut retrofit.
Old Feb 18, 2014 | 12:49 PM
camucho's Avatar
camucho
I need to replace my suspension, nothing fancy, I'll go OE. My car was built feb/2002, has the weird suspension and can't find anything but original equipment, twice the price as those built after 3/2002.
Has anyone changed the front suspension? Can I reuse the springs? I tried different website, but found no info or "Call you local dealer". I found some threads listing the parts I need, but made no reference to the springs.
Comments welcome.
Thanks.
Old Feb 18, 2014 | 01:16 PM
JRhea's Avatar
JRhea
I have a 2002 MCS with the Sport Suspension. I used Pelican Parts and purchased their Sachs Sport struts for all 4 corners along with all of the associated mounts etc. I also had them ship me tower support plates from Maddness. I selected the Sachs because I no longer track my car and I wanted to maintain the original factory ride. These did the trick and I'm glad I went with the Sachs, they were quite affordable through Pelican.
BTW, the Madness tower support plates pulled the slight mushroom down level again when I tightened the installation bolts.
If you're doing your struts you might as well replace your control arm bushings if you haven't already.
Old Feb 18, 2014 | 09:30 PM
camucho's Avatar
camucho
I sent a message to Pelican, I was told the only option for my car is the OEM. I was planning on changing the support plates and the sway bar IF I can reuse the springs. If I can't reuse the springs, then I will have to stay with the current configuration, pay premium for OEM struts and use the car for another 100k....or until it drops flat on its belly.
I do need to change one of the control arm bushings, might as well change both sides.
Thank you for your reply.
Old Feb 19, 2014 | 04:03 AM
JRhea's Avatar
JRhea
Now you got my interest. I'll have to research my Bentley manual to see if the is mention or photos of your setup. Without seeing your setup I can't comment on reusing the springs. I reused mine as the car still maintained its normal ride height.
Good luck with your search
Old Feb 19, 2014 | 05:37 AM
minsanity's Avatar
minsanity
Curious if suspension can be converted to 3/02 version.
YaTuSabe
Aug 23, 2018 11:41 AM
OutMotoring
Mar 3, 2017 06:29 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
buggyeye401
Oct 1, 2015 01:22 PM
Suspension Products
Oct 1, 2015 11:53 AM
