CVT problem R50 2004
Old Feb 18, 2014 | 12:23 PM
mrvnl's Avatar
mrvnl
Hi,
I have a R50 mini cooper with CVT transmission '04.
When you start the car and put D at 1800-200o rpm the car is slowing down (breaking-shifting down) an keep going with low speed. If you kick down the throttle it passing by this "problem" and works fine until you have to slow down and go with low speed so you have tha same again.
What i have already done is to change gearbox,check the dynamo that charges the battery for voltage problems,reprogram the transmission ECU ( everytime i change something), no errors in the diagnostic,no check engine,no EP light (emergency program) the only thing i haven tried is to change the battery.
Th problem is that im filling is getting worse and worse and im afraid its going to have a mechanical problem,(if it isnt already an electrical or ecu problem), because i noticed that if you are moving with 1800-2000 rpm (the rpms i had already problem) and moving about at 60km/h and loose the throttle, the rpms goes to 5000rpm for a second till the car slows down.
if you have any suggestions....you will save me
Old Feb 21, 2014 | 06:33 AM
Aspen's Avatar
Aspen
I assume when you said "change gearbox" you meant changed the gearbox oil? I don't think there is much more you can do. There are a couple of guys in the US that can rebuild these things, otherwise you need a new unit, or swap to a manual, or scrap the car.
Spank
11
Apr 9, 2020 02:23 PM
robbiedowns22
Aug 25, 2015 12:20 PM
polotska
Aug 21, 2015 11:55 AM
Aug 12, 2015 01:24 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
