Need some help pulling crank pulley
I have this tool http://www.harborfreight.com/46-piec...set-37824.html
And I just need to know what to use in the center to press on the crank. The bolt that comes with the puller is too big, and I haven't found anything sturdy enough to be pressed.
I went to the hardware store and picked up a M12 bolt and a bunch of washers since I used that same crow's foot puller from autozone. I had to goto a local hardware store since Home Depot/Lowe's didn't have it. I hear Ace Hardware usually has that M12 bolt
The pictures are gone but it's the same steps as https://www.northamericanmotoring.co...oem-tools.html
His was a M12 bolt that he dremeled short enough.
Did you stop trying to get the pulley off after the bolt threaded in, or were you just unable to get the pulley off? The reason I ask is because at this point if it were me I think I would keep going to get the pulley off first, then with the pulley off cut a slot in the end of the bolt and use a screwdriver to turn it. You could also try to clamp down on it with vice grips and turn.
Wow, I'm sorry, mine didn't do that, if there's not even enough room to get a vice grip on it my only suggestion is using an "easy out / screw extractor", just make sure you don't use one too big to get into the crank threads.
I'm racking my brain to remember if mine just didn't move or if the headless bolt bottomed out, it's been over a year now since I did mine.
I wouldn't worry yet about whether you damaged anything. I have been there before and freaked out only to find that everything was fine.
You can search and find my experience with the crank pulley, but I had one of the 6 mm bolts snap. In the end I had to get a 6 ton 2 jaw puller from Sears and that thing pulled the pulley off without a sweat.
patsum
26
05-29-2021 06:29 PM
larryd96
11
09-08-2015 05:01 AM
M7Speed
09-03-2015 07:48 AM
