Loose jack point won't tighten
Old Oct 21, 2013 | 07:56 AM
Minibeagle's Avatar
Minibeagle
Hey all.
Working on the R53 yesterday and noticed that my driver side rear jacket point has become loose and wobbles.
I quickly tried tightening it, but no go. The screw was turning when I tried to tighten it, but it felt like it was just spinning freely.
Anyone come across this and how did you fix it?
Old Oct 21, 2013 | 01:35 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
As I recall, the black plastic jack pads have a push pin in the center that splays out the detents in the upper part of the pad. Pry out the pin and check to see if the detents are broken.
Old Oct 22, 2013 | 03:48 AM
SSSSSSSS's Avatar
SSSSSSSS
Coordinator :: M2C2
As nc trackrat said, on the R53 and R56 the pad is held in with a pin going through 2 arms that deflect similar to the expansion rivets that attach numerous plastic body pieces on our toys, er, cars. Perhaps someone in the past tried to reattach a loose jack pad with a screw. There's nothing for a screw to thread into unless they used a butterfly bolt and the nut portion is stripped. A new pad is around $13.
Old Oct 22, 2013 | 06:05 AM
Minibeagle's Avatar
Minibeagle
Thanks for the input guys, but it looks like I may have a different (aftermarket?) type of jack point installed on my R53 JCW. Bought it used, so...
My jack points appear to be metal (black aluminium?), not plastic. They are held in with a stainless steel screw. There also appears to be a stainless steel "guide pin" located near the screw that seems to be there to help align the jack point while it's being tightened.
Old Oct 22, 2013 | 06:39 AM
cerenkov's Avatar
cerenkov
Do they look like this?
http://www.waymotorworks.com/billet-jack-points.html
Old Oct 22, 2013 | 06:44 AM
Minibeagle's Avatar
Minibeagle
Originally Posted by cerenkov
Give the man a ceeegar.
Thanks. Now to figure out how to tighten it again.
Old Oct 22, 2013 | 08:35 AM
Capt_bj's Avatar
Capt_bj
problem is the toggle is spinning
try pulling down on the block while you turn the screw ... pull against the screw - this will put force against the toggle and hopefully it will stop turning and allow the unit to tighten . . . don't push up on the screw .. a power screw driver would probably work best - while pulling the block down....
molala
Oct 2, 2015 01:53 PM
DevilMeTaz
R60/R61 Stock Problems/Issues
Oct 2, 2015 06:44 AM
Sep 4, 2015 09:23 AM
Suspension Products
Sep 3, 2015 09:41 AM
