Knocking noise
Old Oct 20, 2013 | 03:47 PM
Husam Hammadi's Avatar
Husam Hammadi
Knocking noise
Hello, i've just bought a 03 MCS and i've been daily driving it for about 2 weeks.
First of all, i discovered this noise which i think might be the dual mass flywheel that knocks at neutral or maybe it's a throw out bearing.
i've been noticing this knocking noise while in gear at around 2000-3000 rpms and even pushing the clutch in doesn't make it go away.. I know it's not the engine since i can rev it to red line in idle and it sounds normal ( i even tried turning off the engine while the noise is there and it doesn't go away. )
It doesn't knock if i am accelerating, mostly when i am applying very little pressure to the gas pedal or when i let off the gas at around 3000 rpms.
I'll try to get a video of it soon hopefully tomorrow.
I would really appreciate some help. Could it be a wheel bearing? a motor mount? trans going bad? Cv axle/shaft or w/e?
I also noticed some white liquid that is kinda oily and has no smell in the garage this week. Motor mount oil? Might be coolant? (checked level and it's not low)
scfiveo
Sep 27, 2019 02:27 PM
unxpectederror
Oct 22, 2015 12:16 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Miniwaukee
Sep 29, 2015 09:22 AM
