Haunted mini cooper
Old Oct 5, 2013 | 10:54 PM
RHcoopers's Avatar
RHcoopers
Haunted mini cooper
So the speedo is freaking out. Friend mentioned it may be the bcu. Considering the car has has minor leaks , the driver side door doesn't electronically lock any more and I have door sill rust... What is the issue?????!
YouTube vid link is here:
Old Oct 7, 2013 | 07:28 PM
usafdrew's Avatar
usafdrew
Are you able to start the car? My speedo did that when the battery was at the end of its life. Might be worth it to have battery tested.
Old Oct 7, 2013 | 08:03 PM
RHcoopers's Avatar
RHcoopers
You and way motor works mentioned the battery and I'm thinking that's the case. I can't still start it up bit sometimes it has to crank a couple times to get going.
Old Oct 7, 2013 | 10:05 PM
RHcoopers's Avatar
RHcoopers
Old Oct 8, 2013 | 04:28 AM
yetti96's Avatar
yetti96
Low battery does weird things. Go get it tested for free and replaced if necessary.
Old Sep 19, 2014 | 07:14 AM
Zlatko Vujec's Avatar
Zlatko Vujec
hello my american friend!
Greetings from CROATIA.
Yesterday i sow that you have a problem with your MINI COOPER,and guys from my garage have a soluttion,because we have the same problem yesterday.
We had the same DTC,same flickr on the dash board,we try everthing and at the end,we replace RPM cluster,and we solved the problem.To be safe first try to disconect the RPM,should be fine with out it.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
