R56 Engine Malfunction Fault: Help Decoding Codes
Old Sep 6, 2013 | 03:40 PM
GorillaArms's Avatar
GorillaArms
All, I recently experienced the dreaded "Engine Malfunction" error that forces the car to run in a degraded performance mode [eg, no turbo]. I received the code twice in the past three days [cleared itself in between]. Both times were under hard acceleration. This leads me to believe core functions such as fuel/spark/air [as opposed to sensors].
I pulled the car in the garage and went through the magic nonsense to pull both the OBD codes and the "special" codes from Menu 14. Sadly, there are _no_ OBD codes. I even verified with a code reader from an auto shop. No OBD codes. However, there are four error codes from Menu 14.
They are as follows:
931B h
A559 h
931F
9314
Any thoughts on how to decode such things?
My plan is to pull the plugs in the morning and see if they're dirty or fouled. I only use 93 octane fuel from Shell, so I don't believe this is a fuel quality issue. I need to replace the air filter, which I'll also do tomorrow, but I can't see an air filter causing such havoc. Might be the high or low pressure fuel pumps. I hope its not the carbon build-up issues found on many R56's.
Old Sep 7, 2013 | 10:29 AM
GorillaArms
Quick update. I swapped plugs and the air filter this morning. The plugs were nasty and I believe original [NGK]. I drove for ~12 miles and added some fuel system cleaner. The code still remains.
I'm going to try disconnecting the battery, then reconnecting and see if the system resets.
At this point, I have no idea what's going on. I did, however, get a few of the codes decoded:
A559
Clamp 30g_f cutoff
Error will not cause a warning light
Error is not currently present
Test conditions have been completed
EXPLANATION: Pulled fuse out behind glovebox during tune install.
FIX: Make sure fuse is inserted. Clear and rescan.
931B = Open circuit in the ambient temperature sensor or in the wiring harness between the ambient temperature sensor and the instrument cluster
Found this post in an Italian forum:
http://www.clubminitalia.com/index.php?showtopic=25081
Old Sep 7, 2013 | 11:20 AM
GorillaArms
As an aside, the fault codes also correspond to:
931B h : 20002F5B8C00
A559 h : 20002F5B7502
931F : 20002F5B7708
9314 h : 2000368B7100
Old Aug 12, 2017 | 12:00 AM
k9182's Avatar
k9182
@ GorillaArms
i have same codes like yours,
A559 h
9314 h
there is not much info available on google. Do you mind to share your experience about how to fix these error codes?
thank you.
Old Aug 22, 2018 | 10:54 AM
7611Mini's Avatar
7611Mini
Anybody figure out the 9314 code? My 07 Cooper S has a terminal case of no turbo and now it's dying on the road and occasionally hard to start. No ODBC codes, though. A mini mechanic suggested the High Pressure fuel pump without looking at it.
Dec 23, 2015 10:36 AM
Zettinger
Aug 25, 2015 04:04 PM
massmini03
Aug 12, 2015 11:19 AM
pewx3
Aug 7, 2015 03:34 PM
