Mini cooling fan LS
Old Apr 15, 2013 | 06:13 PM
jeffsun21's Avatar
jeffsun21
Mini cooling fan LS
Can I swap relays with another R1-R2 to test if the low speed fan not working when ac is on.Not sure if AC is even coming on when switched, which fuses should I check.
2003 S
Old Apr 15, 2013 | 06:27 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Just open the bonnet, start the car, turn the A/C on and check two fans.
First, the one for the PS pump should come on ( use a flash light to see if it spins) and second, the engine cooling fan will come on about 1 min later....that one your should be able to see and hear.
iggi
18
Feb 9, 2026 01:00 AM
Cereall
Sep 5, 2019 06:05 PM
Sexual Chocolate
Mar 31, 2019 08:02 PM
Red Raven
Aug 11, 2015 04:48 AM
mini pooper
RSR Motorsports Coverage
Aug 5, 2015 02:56 PM
