over heating water temp too high??
Old Mar 18, 2013 | 06:17 AM
  #26
Gizmo's Avatar
Gizmo
What kind of coolant did you use? You can't mix coolant types.
Is there a BMW dealer near by? BMW and MINI use the same coolant so you can get the coolant from a BMW dealer as well.
Do you have a trusted independent mechanic near by? They can pressure test the system for a leak.
Old Mar 18, 2013 | 07:54 AM
  #27
minimike21's Avatar
minimike21
So what your saying is my coolant might not be low? I drove it for about an 1.5 hours on a mini road trip yesterday and it never got above 224 on the water temp. It seems to be running fine but I might have it towed in just to make sure
Old Mar 18, 2013 | 07:56 AM
  #28
bmx045's Avatar
bmx045
if you originally had air pockets or were low on coolant, adding to the res tank 1 time may not be enough, as the system is taking in that coolant it needs. sometimes it takes a couple days to burp itself.
Old Mar 18, 2013 | 08:11 AM
  #29
nakman's Avatar
nakman
Hopefully you got our issues burped out... I have a question on your numbers though, is the 220-224 range normal for these cars? Seems hot to me, but I'm still getting used to the MINI way of doing things. I hooked up my Ultra Gauge, so have been monitoring temps and seem to settle in at that range as well.
Old Mar 18, 2013 | 08:15 AM
  #30
bmx045's Avatar
bmx045
I have heard they run on the hotter side of known normals for petrol vehicles. Jeeps as well, with the I-6 back in the day run 210
Old Mar 18, 2013 | 08:29 AM
  #31
nakman's Avatar
nakman
Right on thanks, so you know what I'm talking about. In the land cruiser world where I hang out mostly 210-213 is normal, at 224 the AC shuts off, and by 230 you're pulling over, hoping your head is still flat. I'm going to flip through the Bently manual tonight, hope to find some more definitive numbers....
Old Mar 18, 2013 | 09:53 AM
  #32
boOst spIKe's Avatar
boOst spIKe
Originally Posted by bmx045
The expansion tank is essentially a reservoir for when the engine heats and cools. when the engine is up to temp, everything expands(thermal expansion), when the engine cools, things contract...which is when the engine would take coolant from the res tank. it may fill the tank back up a little when the engine is warm. it's also sort of "self burping", meaning air pockets and bubbles will work their way out of the cooling system, and take needed coolant from the tank. if you had air bubbles, it may take a couple times to top off the coolant res if the engine had a lot of air pockets
QFT.
Glad to see proper information being posted on these boards. As of late it seems there is allot of misinformation going around here.
Old Mar 18, 2013 | 10:29 PM
  #33
Melangell's Avatar
Melangell
Gotta get it fixed, Mike, so you can start catching up with me!!! Loving the LSD!
Cereall
Sep 5, 2019 06:05 PM
KrisMiss
Jan 3, 2016 02:02 PM
Dec 23, 2015 10:36 AM
tylewis
Aug 18, 2015 06:53 AM
