Top of right strut assembly sqeaking when turning the steering wheel.
And, if I put my hand on the unibody where the stut bolts to, where the metal ridge sticks up, I can feel the vibration from the sqeaking noise.
What is causing that squeaking?
Genuine BMW MINI, OE suppliers Lemfoerder/Sachs/Boge(all 3 under same ZF umbrella) or fixed/adjustable aftermarket camber plates are your options. Make sure you check, fix & reinforce those strut towers along the way....then get an alignment.
So with the top mounts being broken, it's time to change them and the struts. If it's time to do the front, it's time to do the back. I might as well spend a couple hundred dollars more and go the coilover route. I'm thinking Megan coilovers.
Dec 23, 2015 10:36 AM
minipopkart
Aug 13, 2015 05:22 AM
