Rounded oil drain plug
Old Aug 26, 2014 | 04:14 PM
  #26
Joeygonz's Avatar
Joeygonz
Originally Posted by ra2fanatic
I would say after every.....4-5 oil changes, I'll take it off and hit it with some brake cleaner. Cleans up all the road debris/dirt that would get caught in the spring loaded lever. I've had it for well over 40k miles now with NO ISSUES.
At least on the R56 I have the undertray so I never worry about anything flying up and hitting it, or getting caught on anything that would flip the switch, haven't come across anything of that nature.
Also, as far as removing the tray, they're quick release screws, so it's not too much of a pain to crawl under and remove, but I can see what you're getting at and I'd honestly would rather not cut out a hole to gain access to it. I like crawling under there anyways because while I'm doing it, I can also inspect underneath to ensure nothing is leaking or loose.
Thanks for your review / feedback on the undertray! Much appreciated... Always good to see a snapshot of what's going on underneath there.
Old Aug 26, 2014 | 07:08 PM
  #27
BRGPA's Avatar
BRGPA
I've have a Fumoto on my 2003 S for many years and I've never cleaned it; works perfectly. To make sure the lever could never move by accident I put a small spring clamp on the housing- not really my invention- it was mentioned on something I read by Fumoto as a backup in extreme conditions. I'd do it again in a heartbeat!
Old Aug 27, 2014 | 06:31 AM
  #28
WhoHasGotTheBlueS's Avatar
WhoHasGotTheBlueS
Glad to hear another vote for the Fumoto. It is tempting... Seeing as I just changed the oil, I have some time to think about it. Maybe it will go on sale between now and the next change.
Old Aug 28, 2014 | 05:08 PM
  #29
inteva6184's Avatar
inteva6184
I also had the drain plug issue. I attempted to break the slightly rounded drain plug loose with a snapon wrench and that just completely rounded it. I then used a snapon extractor and rounded it more. I decided to buy a brand new set of craftsman extractors and they just rounded it smaller. I tried vise grips and again they just removed more metal. There is almost no head left so I am screwed. I have never had this issue with any car before. I am to the point where I will need to remove the pan and weld a nut on to try to break it free. I feel like they use a cheap metal for the plugs. Sorta like everything else on the car.
Old Aug 28, 2014 | 05:27 PM
  #30
WhoHasGotTheBlueS
Uggh. That sounds painful.
I wonder if a muffler shop could weld the nut on in place without your having to remove the oil pan.
As to the drain plug material, I wonder if you are on to something there: it might make sense from an engineering perspective to use a mild steel since it is threading into an aluminum hole, to protect the aluminum more than a stronger steel would.
If so, to me anyway, it strengthens the argument for a Fumoto valve, or perhaps an aftermarket magnetic drain plug depending on what material they use to make those...
Old Aug 28, 2014 | 05:48 PM
  #31
Joeygonz's Avatar
Joeygonz
Lately, been thinking of a magnetic drain plug as a replacement. Only issue that I can see is.... the bolt's head is pretty short that can be prone in being rounded. Since it also needs to be torqued I figured it has to have a pretty secure connection between the socket and the plug.
Has anyone used an aftermarket magnetic plug like Dimple?
A Fumoto valve may have a clear advantage over the magnetic plug?
Old Aug 28, 2014 | 05:49 PM
  #32
inteva6184's Avatar
inteva6184
It sure is. I have a mig and I have thought about welding a nut to it but I am fearful of getting the nut to hot and starting a fire within the oil pan. I am also concerned if that doesnt work it will melt the rubber and leave me with a leaking stuck plug and I will be forced to immediately pull the pan.
What you are saying with the plug material make sense but my s2000 had an aluminum pan and for the 6 years I owned the car I never rounded the plug. I keep trying to find a positive to the mini but so far I am struggling.
Old Aug 28, 2014 | 06:02 PM
  #33
WhoHasGotTheBlueS
Until last week, I had a 2000 VW GTI that had an aluminum oil pan like the MINI and your S2000. In fact I was the original owner and sold it 14 years, almost to the day, after buying it. While the drain plug did not have the same issue as we have on the MINI, one of the shops I took the GTI to managed to strip out the threads in the aluminum oil pan. It is a common thing on VWs.
Of course that could still happen with the MINI, but if the MINI drain plug is a milder steel, the aluminum pan might stand a better chance to put up a fight. I am not saying I think the design philosophy is proving to be a successful one, mind you. I am just saying I can see why an engineer might design it that way, not understanding the consequences of that decision when the seal bonds as well as it apparently does...
Old Aug 28, 2014 | 06:20 PM
  #34
WhoHasGotTheBlueS
I too have been considering a magnetic drain plug for my MCS. The prices I have seen for them have been comparable to that of the Fumoto. If the head does round off, then the Fumoto should prove to be less expensive long term assuming it is as reliable as its fans attest.
Old Aug 28, 2014 | 07:36 PM
  #35
michi1201's Avatar
michi1201
Yes re: Dimple magnetic drain plug
It is a strong, well made plug. The only problem is that the magnet is so powerful it can pull the plug out of your hand and stick it to the oil pan with great force. Be prepared!
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
