Changed Key Fob, now car won't start...
Old Sep 13, 2012 | 12:56 PM
Keyser_Soze's Avatar
Keyser_Soze
Like many of us, the "lock" button on my Mini S key disintegrated and stopped working... The problem was the button on the plastic casing which the key is inserted into and locked with a pin... No problems, except I had to use the key to manually lock the doors... Knowing the exorbitant cost of a new key from Mini, I located a new key casing on eBay for $18 USD... So I ordered it and it arrived last night... I took the key assembly apart and replaced the plastic parts with the new parts, then re-assembled the key... All of the internal electronics are original, along with the actual key itself... The lock/unlock buttons work fine now, but the freaking car won't start!!! I insert the key, turn it to the on position and all the indicator lights come on, but when I turn it to the start position, nothing happens...
Knowing that these cars are sensitive to different keys, what could possibly be the problem? All of the key internal bits are the same as before and only the plastic bits have been changed... Is this issue related to fixing the key -or- is it just a coincidence that something in the car failed at the same time? It seems ludicrous to me that the car would break at the very same time that I repaired the key...
Any assistance would be appreciated...
Old Sep 13, 2012 | 01:09 PM
tremperj's Avatar
tremperj
You sure you transferred over the immobilizer chip? Its tiny and easily missed.
Old Sep 13, 2012 | 01:14 PM
Keyser_Soze
Nope, not sure about an immobilizer chip... There was nothing in the instructions that came with the new plastic bits. Now the problem is that the old bits are in the garbage...
Old Sep 13, 2012 | 01:21 PM
Keyser_Soze
That has to be it... I just found this thread that shows the immobilizer chip...
https://www.northamericanmotoring.co...rbishment.html
Now I have to dig through the garbage looking for the chip... If I don't find it, I guess I'm out $195 for a new key... Fark!!!!
Thanks for the quick response...
Old Sep 13, 2012 | 01:22 PM
tremperj's Avatar
tremperj
That SUCKS. Good luck.
Old Sep 13, 2012 | 02:59 PM
Keyser_Soze
That was it!!!! I dug the old fob out of the garbage and the chip was still in place. So I popped it out and put it in the new Fob and voila, the cars starts... I had no idea that Minis had an immobilizer built in...
Thanks for the tip.
Old Sep 13, 2012 | 08:43 PM
tremperj's Avatar
tremperj
Glad to help.
Also: awesome screen name
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
tippin
Aug 5, 2015 08:43 AM
