A/C is smelling pretty bad....
Old Mar 21, 2004 | 06:17 PM
DavidR.'s Avatar
DavidR.
As long as the A/C is on, it's fine. But when I go back to outside air I get this very musty, sour kind og smell out of the vents. If I roll down the windows and put the fan up to full it takes about 5 minutes for the smell to go away.
I suspect that it might be a filter that has gotten funky or maybe there is some residual water in the system that has gone foul. Has anyone else had this problem? I didi a search of the forums, but didn't come up with anything.
Old Mar 21, 2004 | 06:29 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
Sounds like there's an issue with mildew somewhere in the A/C ducts. Besides checking the filter, one way to resolve the problem is to spray Lysol anti-bacterial spray into the air re-intake vents while running the A/C system in the re-circulating mode. Do this several times and that should help to eliminate the mildew causing the smell. :smile:
Old Mar 21, 2004 | 06:49 PM
kenchan's Avatar
kenchan
where is the air re-intake vent located?
Old Mar 21, 2004 | 06:54 PM
dcsmd007's Avatar
dcsmd007
In most cars, they're usually located around the footwell region. I believe the MINI should be the same. :smile:
Old Mar 21, 2004 | 07:01 PM
gokartride's Avatar
gokartride
I've heard stories from local owners about foul smelling filters (dirty socks if I remember), but that should affect the AC, too, right???
Old Mar 22, 2004 | 02:55 PM
g3's Avatar
g3
I'm having the same problem. I heard the guys on Car talk say something about a product called Frigi Fresh. I stopped by my local Pep boys and they had a similar product (I threw it away and can't remember what it was called). But it was a little spray container with a plastic hose. It sprays a foam-like substance into the recirculating air-vents and into the vents coming from the outside. It's supposed to coat everything and prevent the mold from accumulating.
I tried it out this weekend. After doing some experimenting with a tissue, It appears that the intake vents inside the car are actually up on the dash and not on the floor board. Does that sound right?
On the outside. I couldn't directly find the vents under the intake filters under the windshield so I just sprayed it as close i could to where I felt air going in (I had the A/C on full blast).
It seems to work so far - it will take a couple of weeks to determine if its a long-term fix.
My 4-yr old daughter says the MINI smells like Krispy Kreme donuts now, much better than stinky-feet
Old Mar 22, 2004 | 03:12 PM
tontobird's Avatar
tontobird
I'm curious about something, do you all have the automatic air conditioning or the regular A.C.?
Old Mar 22, 2004 | 03:16 PM
g3's Avatar
g3
I have the regular AC and I live in the ever-humid city of New Orleans.
BlueMCS's Avatar
BlueMCS
These work nicely.
Old Mar 22, 2004 | 08:07 PM
kenchan's Avatar
kenchan
danke. :smile:
Old Mar 22, 2004 | 08:30 PM
tontobird's Avatar
tontobird
BTW, the reason I ask is that I have 2 MINI's and one has auto AC, the other regular. The auto doesn't smell, the regular does.
The auto AC comes with a special micro-filter or something like that. I wonder if that has anything to do with it?
Old Mar 23, 2004 | 02:54 PM
DavidR.'s Avatar
DavidR.
I have the auto A/C and it smells. I think that I will try the duct coating stuff and do a good clean out to see if it helps. The smell is really sort of disgusting right now and I want to get it handled before summer.
patsum
26
May 29, 2021 06:29 PM
rob&JCW
Oct 9, 2015 11:12 AM
Quixotic1
Sep 11, 2015 11:15 AM
doug5g
Sep 2, 2015 04:53 PM
Sep 2, 2015 09:05 AM
