yet another thing...
Old Mar 27, 2012 | 02:29 PM
Tora-blitz's Avatar
Tora-blitz
07 mini cooper s, 65k miles
ok so ive had my car a total of 3 weeks give or take, and after getting the noises fixed from the fly wheel and my possessed sunroof, i now have a slight front suspension squeak when goin over a bump that loads and unloads the suspension much louder when the windows are open. doesnt happen when i hit a good sized crack in the road. any Ideas? im going get underneath it tomorrow and see if i can see where its coming from but its really irritating and if its something big then i have to bring it back cause its still under some kind of warranty. expected from a used car so its not a big deal, this car is a keeper
Old Mar 27, 2012 | 03:53 PM
proximo's Avatar
proximo
It could be a bad ball joint, tie rod, control arm bushings, sway bar bushings, shock or strut bushings, coil spring seat ... I'd venture for the shock/strut bushings first.
Old Mar 27, 2012 | 10:48 PM
Tora-blitz's Avatar
Tora-blitz
Thanks for the advice, hes getting put up in the air at my shop tomorrow so i can check it out
Old Mar 28, 2012 | 02:40 PM
Tora-blitz's Avatar
Tora-blitz
So i found out that its the sway bar bushings in the front making noise they were squeaking so i sprayed a little lube on them and now there quiet atm but one had a little play in it.
If i replace them would it be better to go factory or aftermarket? options? do they make an upgrade for them?
Old Mar 28, 2012 | 02:55 PM
proximo's Avatar
proximo
Sometimes aftermarket ones are massively better than stock. One example is Pedders urethane bushings. I don't think Pedders makes them for Mini's, but MiniMania has ones by Powerflex (don't know them at all). The benefit you'll gain from urethane over rubber is a stiffer transfer of power/support. I'll see if I can find any other manufactures and post later on if I find them.
Old Mar 28, 2012 | 02:59 PM
proximo's Avatar
proximo
Whiteline (a line I'm familiar with) has replacements for the 22mm and 24mm bars. I'd trust theirs, but would not rule out the other too.
Old Mar 28, 2012 | 03:03 PM
Tora-blitz's Avatar
Tora-blitz
Know any reliable websites i can check out? and that would also mean i have to measure my current sway bar
Old Mar 28, 2012 | 03:08 PM
proximo's Avatar
proximo
I would have said Andy's Autosport ... but I just realized the bushings are for the R50 line, not the R56 line. Sorry about that. Still hunting.
Old Mar 28, 2012 | 03:15 PM
proximo's Avatar
proximo
Here's another brand I'm familiar with, but haven't used
http://www.powerflex.co.uk/products/...+2-2626/1.html
Here sells them too
http://www.outmotoring.com/mini-coop.../2-suspension/
You'll def. need to see how large your bars are as they seem to go from 16mm - 25mm.
Old Mar 28, 2012 | 03:44 PM
Tora-blitz's Avatar
Tora-blitz
lol its all good i already looked there also, i might just put the factory one's in depending on how much they are.
boholio
Nov 9, 2015 03:50 PM
yashmack
Aug 15, 2015 03:11 PM
Mr_Bueno
Feb 11, 2012 01:00 PM
Bubble and Squeak
Nov 29, 2011 03:08 AM
Pirate007
Aug 17, 2011 03:48 PM
