Half full check engine light came on
Old Dec 26, 2018 | 07:11 AM
  #26
Wolfe52's Avatar
Wolfe52
Level indicator
Don't wait for level indicator lights to come on. My oil was seriously low and no indicator.
Also, anyone else have trouble reading the red plastic end of 2008 Mini oil stick? Any tips? Thanks .
Originally Posted by Alvajosh
Hi My name is Josh, I have a 2009 Mini Cooper S Clubman, My car just started to give me the half yellow engine warning today. This is a Warning Light not a Check Engine Light, so it won't give you a Trouble Code. I have a OBD2 Scanner and the cars is clean, no error codes, permanent codes, nor pending codes. Please trust me I am a former mechanic. This light comes on and off randomly. I think it's due to me driving this car fast as hell, and lagging on taking it to get an oil and fluids changed. I know you have been at that red light gunning it when it turns green like you have to be the first to pass that crosswalk at the other side of that intersection to show people that you may be in a small vehicle but this one is powerful and not one of those stupid FIATS. And for those that are saying that Mini's were badly engineered, don't blame the car. Blame yourselves! I know all of you didn't check your fluids periodically like mentioned in the cars bible. How do I know this? Because I did the same thing, and now I'm gonna pay the price. So stop putting the car down, if you take care of something the right way, it will last you. In my case, I think what is going on with my car based on what I have read here, is that I may have overheated my car a bit because lately it's been hotter in Moreno Valley. Why did it overheat a bit, simple... I didnt check the engine coolant, I know it's not empty and I still haven't checked it because I haven't gotten a Low Coolant Light. but I know I should still check because the Coolant Sensor may be bad. The overheating may have caused a small gasket leak and that may be triggering the half engine light. It's just common sense.
Old Jun 6, 2023 | 08:37 AM
  #27
luffy's Avatar
luffy
I apologize for bringing up this old thread. I had a similar issue with my vehicle recently; I didn’t know what to do at first but when I hit up the internet, I came across an in-depth article that may be worth reading. Search for "BMW Check Engine Light Half vs Full Meaning on YOUCANIC" and you will see an article that goes over common causes and possible fixes. You can read about it yourself. I hope this information can assist someone else with a similar issue.
Old Jan 11, 2024 | 05:14 PM
  #28
GKS's Avatar
GKS
Same issue, no resolution
Mini 2010 S, convertible, 32K miles. I have same issue engine light on then half full check engine light came on.
Tow mechanics checked, spent $$$$ but no luck. They said engine needs to be replaced.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
