IMPORTANT: AIR CLEANER IN YOUR COOPER...
#27
#29
Are there any guides for replacing the air filter?
On a sidenote, can you get an upgraded air filter for an 05? I'm not much of an engine guy, so I'm not sure what a lot of the stuff means. I drive my Mini around a coke(the stuff for steel, not the drink) plant and have to wear a respirator at times, so I'm imagining my filter is getting slammed with coke dust.
#30
on
You will be looking for a long time. This car does not have a MAF. The computer only uses the exhaust levels. With the Super Charger, you want to get a LOT of air in there, so you should welcome it, not restrict it.
The Alta filter helps you in this, as the K&N Typhoon CAI. The Alta filter element comes with way too much oil. Make sure you remove some of it or it will make its way to the SC. I know because I have seen it.
The dirtiest K&N filter is suppost to allow more airflow than a stock filter. I am sure that this can not be completely true, but they are better than stock.
Bomboasy
Bomboasy
Originally Posted by kenchan
btw, has anyone had any problems with the supercharger sucking too much
air through the K&N filter damaging their MAFs with the oil from the K&N?
(im not even sure where the MAF is on this car yet...need to take a closer
look.)
_________________
03MCS IB/Blk: 123, Aerokit, R90 17x7, Anthrasite Int, TK5 16x7, 6CDMP3, etc.
<a href="http://hometown.aol.com/teined/index.html">more info</a>
look.)
_________________
#31
I just checked out my filter and its a mess at 27,000..
Can someone tell me how to remove the hose clamps, and if it is possible to put it back on the hose? I just had to squish my airbox around a bit instead of removing the clamps to get access to my air filter.
And one last thing, could I purchase a K&N air filter at a local pep boys?
#33
09-10-2015 11:55 AM
kjd186
09-09-2015 10:02 AM
