Boot will not latch
Old Oct 21, 2011 | 06:49 PM
saturn5rocket's Avatar
saturn5rocket
Boot will not latch
I have a 2002 MC. The rear hatch has been rattling alot. I have just lived with it, but now the hatch will not latch. Is this an easy DIY fix?
Old Oct 24, 2011 | 10:17 PM
abjb's Avatar
abjb
Could be easy.
Check this link to RealOEM.
http://www.realoem.com/bmw/showparts...80&hg=41&fg=60
Parts 8 and 9 are what need to be checked first. They might be loose.
8 is on the body
9 is on the “Trunk Lid” hatch.
Hope this helps
ab
Old Oct 26, 2011 | 03:40 AM
MadisonKobalt's Avatar
MadisonKobalt
Have you checked to see if the hinges are ok? See NAM link. Also check parts item #5. There are 2 rubber stop buffers on the lid. They may need to be adjusted in or out depending on if it is making tight contact.
Old Oct 26, 2011 | 07:27 AM
buzzsaw's Avatar
buzzsaw
There's a couple of links on the site below under the "exterior" tab that addresses boot issues. Hope that helps.
Old Oct 26, 2011 | 07:36 AM
colinmini's Avatar
colinmini
Check your hinges, I heard of a few rusting out.
Old Oct 30, 2011 | 10:20 AM
saturn5rocket
Thanks for the info. The boot has mysteriously fixed itself??? It now latches and doesn't rattle....go figure. I'm still going to keep my eye on it
Old Oct 30, 2011 | 10:23 AM
saturn5rocket
I've already had my hinges replaced. I had a problem with the hatch not lining up properly. It was about a 1/2 inch out of alignment and actually hit the bumper when you closed it. One hinge actually snapped in half when I tried to adjust it.
Old Nov 2, 2011 | 08:03 PM
SniperDetailing's Avatar
SniperDetailing
hey guys, my mini is having the same problem now. for a little bit my boot wouldn't open, then it just made a series of like 5 weird clicks and now it won't shut at all. I just went out there and manually closed it with a screwdriver so it's latched, but I think something is up with the mechanism because it's perfectly aligned and the mechanism is tight lined up.
Old Nov 3, 2011 | 08:15 AM
SniperDetailing
never mind, my hatch fixed itself too. made me look like a fool when I went to have it looked at and the tech just straight up opened the boot that was supposed to be stuck
gknorr
Dec 26, 2016 09:38 AM
vetsvette
Oct 22, 2015 09:46 PM
vetsvette
Oct 2, 2015 05:32 PM
gknorr
Oct 1, 2015 09:20 AM
aldito2
Sep 30, 2015 10:44 AM
