Replacing hatch hinges
Old Oct 21, 2011 | 05:10 PM
pew1375's Avatar
pew1375
I need to remove/replace one of my rear hinges. I bent the left one, and want to try to bend it back. I do have a replacement set, just in case. I know I need to get under the headliner, and I am sure it won't be too hard. Just hoping for some info or tips if anybody's got any experience with this!!
Old Oct 23, 2011 | 05:34 PM
buzzsaw's Avatar
buzzsaw
Click on the link below and then on the interior tab on the right--you will find several links about the boot that may be helpful. Good luck.
Old Oct 24, 2011 | 07:20 AM
ufomini's Avatar
ufomini
If you are talking about the hydraulic levers that hold up your rear hatch lid, Easy. The new ones just clip in. 5 minutes and your done.
Old Oct 25, 2011 | 06:12 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Pull the headliner down and its just one 13mm nut to take it off, then the torx on the hatch. If it's bent I wouldn't bother trying to bend it as you prob won't ever get it lined up.
Old Nov 4, 2011 | 06:27 PM
pew1375's Avatar
pew1375
Got both hinges replaced today. The only problem I had, was getting the rear pillars off so I could pull the headliner down without damaging it. I'm not sure why, but the pillars are attached with a strap? Got it figured out, it wasn't as easy as I thought. I got the new hinges on, which was the easy part, and even getting the hatch perfectly aligned was easy.
But, in the end, I got her put back together, and didn't break anything. It'll be nice not getting the exhaust smell in the car, and the sound outside should stay outside.
Glad I was able to do it myself, so I can help somebody if they need it. But if I have to do this again, I won't be looking forward to it!
nismo4life
Nov 4, 2015 09:18 PM
mrjolliff
Oct 9, 2015 05:55 AM
Powershift
Aug 16, 2015 05:14 PM
Glamrock
Aug 11, 2015 06:28 AM
