Electrical Jitters - Gauges
Old Aug 30, 2011 | 08:28 AM
Filmy's Avatar
Filmy
This only happens sometimes when I turn the key from 0 to start quickly (bypassing positions 1 & 2).
My fuel, temp (and other) gauges click and jitter for a second or two, then level off normally. I'm not terribly worried about it unless it's a sign of some failing component.
Any ideas?
'06 R53, no navigation or chrono, btw
Old Aug 30, 2011 | 06:15 PM
Haseo461x's Avatar
Haseo461x
Mine tend to do that randomly too. or at least when i notice it.
It also happened when my battery was dead.
Old Sep 16, 2011 | 10:41 PM
Filmy's Avatar
Filmy
TTT, for some weekend viewers and insight.
Still have the problem. Low battery? AutoZone checked it out fine. How about the starter drawing too many amps? I really can't afford to get stranded with a dead battery or starter issue first thing in the morning.
Old Sep 25, 2011 | 12:30 PM
Filmy's Avatar
Filmy
And now, adding to the above problem, my power door locks have (on random start-ups) begun to cycle. Does this sound like a battery problem to anyone?
Related note: I had been leaving my portable navigation module plugged into the cigarette lighter while the Mini sat overnight. I know the lighter socket isn't hot when the key is off but just to make sure that wasn't the problem, I've started leaving that unplugged.
I'm going back to A-Zone to recheck the battery.
Old Sep 25, 2011 | 04:03 PM
Filmy's Avatar
Filmy
So, an update.
Did the battery check again at AutoZone. Said my battery (factory, from '06 or so) was "at 60%". Makes sense, +5 years old. Replaced it. (And at $135! WTF?)
If I don't post anything else on this thread, that WAS the problem. I'll know in the next couple of days if/when the jittery gauges stop.
Side note about battery replacement: the radio and all gauges retained their memory, so I didn't need to reset anything after having no battery for around 20 minutes. Good on Mini for allowing this to happen.
USNAE2
16
Jun 17, 2022 07:17 AM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
aldito2
Sep 30, 2015 10:44 AM
