Aux Driving Lights
Old Aug 21, 2011 | 07:23 AM
Chili_head's Avatar
Chili_head
Aux Driving Lights
Just picked up an MC40 and the driving lights are not coming on. Before I chase the wiring (after checking the bulbs), has anyone else had this happen? Tips? Tricks?
TIA-
Old Aug 21, 2011 | 08:18 AM
Capt_bj's Avatar
Capt_bj
factory instaled driving lights will only come on when the bright/high beam are on. Is this how you are checking?
If yes and they still don't come on, the next thing I would check would be the inline fuse for the main power feed for the DL's. You should find a wire coming out the back of the engine compartment fuse box, attached to the same lug as the main battery cable. Trace this wire towards the firewall and you shoud find an in line fuse holder. Check this fuse . . .
If still no then there is a wiring problem that will be a bit harded to find
here's the factory install instructions http://www.minimania.com/pdfile/NMA3030_INSTR.zip
Old Aug 21, 2011 | 08:42 AM
Chili_head's Avatar
Chili_head
Well, now I feel a bit silly. Seems I missed the switch on the lower part of the lefthand dash. Thanks for the quick reply.
Wohnson89
Jun 10, 2020 04:53 AM
surfblue
Oct 24, 2018 01:20 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
