Help me diagnose this noise.....
Old Aug 6, 2011 | 06:03 PM
zcast's Avatar
zcast
Ok, so I had a blast at MITM but had to head back to Vegas a day early due to prior commitments. We left early and drove straight thru, just like we had on the way there. No problems on the way to MITM, but on the way back I started to get this buzzing noise from the drivers side engine compartment. I have experienced this noise before MITM, so you can't blame the mods I got done while at MITM. (More on that later)
Anyway, when I heard it last, it was when I had really got on the throttle trying to pass a drunk driver on the highway, so I wanted to get by him asap, so I gunned it. When I got into the higher speeds (high highway speeds) I got the noise. It was a constant sound until I let off the throttle (maybe only a second or so.) I had also experienced it when getting on it while entering the highway. I have only experienced it in those circumstances until today.
Once I started to get into the warmer climate (driving out of Colorado and Eastern Utah, and into the 100 deg desert) is when I noticed it. Didn't have a problem at all while at MITM. I had the A/C on and we were cruising at highway speeds (speed limit 80mph in Utah). After I first noticed it, I tried to see if turning the A/C off would remedy it, but after a few minutes, it came back. It is completely sporadic and even when trying to make it occur by slowing down to 60mph then gunning it up to 80mph, it wouldn't always trigger it.
The video below is me traveling at 85mph using cruise control. No hard acceleration, A/C on. You can hear it kick in once or twice before the longer buzz. Then it goes out and a second or so later another tiny hit. It was like that for the last 2 or so hours of the trip. Mainly on Cruise Control and always around that speed.
Let me know what you think, I want to have this checked out asap.
-z
Old Aug 6, 2011 | 07:26 PM
DneprDave's Avatar
DneprDave
Bad fan bearing?
Dave
Old Aug 6, 2011 | 07:48 PM
Locust's Avatar
Locust
do you have a 15% pulley vibrating against something? Sounds like a loose pulley or shaft. But I am no mechanic... Take her in and get it diagnosed as soon as possible.
Old Aug 6, 2011 | 07:59 PM
zcast's Avatar
zcast
No pulley. I forgot to add, its a R55S 2008.
The sound happens with or without the A/C on.
I thought it might be a bad or struggling HPFP, but I see/feel no lack of power when the noise occurs, then again, I don't try to push it when I hear the sound.
Fan seems fine every other time it is in use, so why only make noise when at high speeds? I don't know.
Old Aug 6, 2011 | 08:14 PM
2009R56JCW's Avatar
2009R56JCW
Waterpump , vacum pump or altenator bearing.
Old Aug 7, 2011 | 06:23 PM
zcast's Avatar
zcast
Thanks, I will suggest that to the service tech.
Old Aug 24, 2011 | 10:38 PM
element's Avatar
element
what was it?
Old Aug 25, 2011 | 03:16 PM
zcast's Avatar
zcast
I have yet to bring it in to service as I have been traveling for work. I am going to try to get it in next week to see if they can find out.
Old Aug 25, 2011 | 03:34 PM
automan21's Avatar
automan21
Sounds like something more in the cabin than in the engine bay. Im curious to know what it is also.
dinomaniac
Sep 18, 2018 04:19 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Miniwaukee
Sep 29, 2015 09:22 AM
silence2-38554
Sep 28, 2015 12:19 PM
