service engine soon light
Old Oct 7, 2002 | 06:27 PM
baldrichguy's Avatar
baldrichguy
I sent my mini to Brian Harris Mini to cure a "service engine soon". The first time it was returned with the light still glowing.
Then they replaced the air pump associated with the catalytic converter / emission control system. The second time it was returned, the light was off but it came back on the next day.
I am in Austin, TX and BH Mini is in Baton Rouge Louisiana and it rides on flatbed carriers the 400 or so miles between cities. The car is gone for a week each trip. I haven't sent it in a third time.
Harris is the nearest dealer, but there may be one or several this months in a couple of Texas cities.
Anyone else having this type experience?
Old Oct 7, 2002 | 06:46 PM
invaliduser's Avatar
invaliduser
I don't blame your for having it trucked to BR. The interstate ride is absolutely horrible between Houston and BR. (Austin to Houston is pretty good if you take 71)
I heard a new dealership is open and operating in Dallas. I would guess they have a full service shop as well.
Hope this helps.
Good luck.
IU
Old Oct 7, 2002 | 07:19 PM
Sarcux's Avatar
Sarcux
Easy fix. Cut a circular peice of electrical tape and stick it over the indicator.
Old Oct 8, 2002 | 07:16 AM
docjchan's Avatar
docjchan
I had a similar problem, I had 62 miles on the clock when I have the service engine soon light come on with a loss of power. The service people replaced the accel pedal and the tach since I also had a high idle. I drove the car a couple of days and at 151 miles on the clock, the light came back on with a loss of power. The service guy's traced the problem to bad connectors on a plug, the wire connectors were not crimp properly, they showed me the clips. Since then I haven't had a single problem and it's motoring just fine. I'm not sure which plug it was but I sure the service manager (Gary King) at mini of Peabody MA would be willing to help you out.
Old Oct 18, 2002 | 08:44 AM
jstiell's Avatar
jstiell
I had that problem as well, including a loss of power. Would happen for a while and then go away, and then come back again. The dealer said it was a faulty "throttle unit" and ordered a new one, whatever it is. No problems now, thank goodness as it was pretty scary to suddenly almost stop and only inch along. Has your problem been fixed?
09R56
Nov 16, 2022 10:49 AM
W0TM8
Dec 19, 2019 07:50 AM
oldkid6
Aug 11, 2015 08:13 PM
