Stuck removing bypass valve
Old Apr 30, 2011 | 11:25 AM
Mikey52's Avatar
Mikey52
I'm in the process of trying to remove the stock bypass valve, I'm folling the instructions found here.
I have the intercooler off but I am failing at removing the intake tubing. I was able to pop the clamp off the top tube but I can't seem to remove it. The other end of the pipe goes into the bottom of the airbox and there's a tube that goes straight down out of the bottom. I cant for the life of me figure out how to get it off.
The lower intake tube that goes into the throttle body looks a bit tricky as well but I am assuming once I get the top piece off access to that clamp will get easier.
yukinoinu
14
Jul 2, 2016 07:27 AM
wkp1219
Nov 13, 2015 07:52 AM
greekzilla
Aug 23, 2015 03:44 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
quickquest88
Aug 8, 2015 08:45 PM
