Timing chain issues
Old Mar 25, 2012 | 06:07 AM
  #426
tjtull's Avatar
tjtull
Originally Posted by drsimmons
Your entire experience over the chain sucks. Really sorry that the dealership didn't step up to the plate. You are correct, all the dealerships should treat this issue the same just not a randum few. Thank God I've got a good dealership.
Anyway, good luck to ya and I'm sure you'll enjoy your new car which is
most likely alot more reliable for you.
Thanks Dr. S! The kicker is, my MCS was very reliable and never gave me a single problem, until this issue came up. I'd have kept it forever if MINI (and my dealer) had only done the right thing. I even thought about trading it for another MINI but I guess this experience soured me on my dealership. That's what you get when there's only one dealer in a 300 mile radius. Conversely, there are 7 Honda dealers in the St. Louis area alone!
The CR-Z is a very cool car! I picked it because of it's sporty looks and it's great gas mileage. I'm not out to race every car on the road, so it's responsive enough for me. However, it'll definitely take some getting used to...after all of the power my MINI had.
Here's a pic:
Old Mar 25, 2012 | 06:17 AM
  #427
drsimmons's Avatar
drsimmons
Old Mar 25, 2012 | 07:24 AM
  #428
MiniRy's Avatar
MiniRy
So i after reading thru this forum, I am worried now about my purchase of 2008 MCS with 37K miles. The car seem to run like new (test drove new ones) and everything seems to work great, starts right up.
So are there any warning signs for this issue before the bad stuff happens? I checked what little service log this car has, and I do not see any mention of a timing belt fix.
I have 3 months left on the factory warranty, should I / can I buy an extended warranty?
-=Ryan
Old Mar 25, 2012 | 08:12 AM
  #429
drsimmons's Avatar
drsimmons
-=Ryan
The OP that ended up trading in his actually stated he loved it but with the timing chain issue being so bad and the dealership not bumping him up to fix it, he opted to trade it. He also stated it's been great besides the timing chain issue. It's his only car also.
So, you've got a little warranty left and you may never have the timing chain issue but you may at some point. Just can't tell you ya or nay.
If you can afford the extended warranty that'd probably be a good thing.
My 07 MCS went to 62K before the timing chain acted up. It came on all the sudden. Will sound like a diesel or rocks bouncing around in the upper left of engine. Mine was not as bad sounding as the one guys however and I was able to have it fixed within a couple weeks of it going bad.
I always check my oil (no low oil) so that was not the cause. The original adjusting bolt for the tensioner seems to be the main issue. Mini has since put out a longer bolt that is suppose to fix the issue. You might ask your dealer about just replacing it for now. I believe that's pretty cheap. Ask them what they think. That may prevent you from ever having an issue with the chain. No guarantees though.
Mine has been fixed since Dec and no problems. Also, mine was out of warranty. The entire replacement which included chain, tensioner, guide, seals, etc. was like $1700. My dealership submitted $1200 to Mini and I paid $500 which was ok with me. So, you can either buy the extended warranty or put away some money in case.
The only other issue I've had with mine is the thermostat leaked which was about $400 to fix. So, in conclusion so far I've had to put out $900 in needed repair since last Aug. 2011. I've put 8K on the car so far and it runs great. No problems.
The only other issue Mini S's have is with carbon build up. I haven't had that problem arise.
A few things:
1. check oil at least once a week. S's can use a little oil if you run them hard. Don't overfill it however.
2. check coolant bottle weekly also. If thermostat develops a leak your coolant level will drop within a couple of days. I never noticed any coolant on the ground.
2. run highest premium gas you can. It will help reduce the amt. of carbon build up.
I know this is long and I'm not trying to scare you off but just make you aware of potential issues and how to possibly reduce them.
Otherwise, enjoy the car and don't be afraid. It's well worth it.
Old Mar 25, 2012 | 12:18 PM
  #430
MiniRy's Avatar
MiniRy
DrS, thanks for detailed response. Very helpful!
Old Mar 26, 2012 | 01:40 PM
  #431
MiniRy's Avatar
MiniRy
So I called my local MINI dealer for a price on the extended warranty and for my 08 MCS with 38K miles will be $3291.00 for 5 more years to 100K miles. A friend of mine just purchased an extended warranty for his 07 lexus 250 and for 5yr 100K miles he paid $1300.00. So either BMW over-charges for everything, or they know something is going to go wrong -- the bean-counters know. Just say'n.
Old Mar 26, 2012 | 02:05 PM
  #432
drsimmons's Avatar
drsimmons
Yea, tough decision. Mines paid for so it's not as bad to have
to dish out a little once in awhile. Hopefully, most is behind me.
I've been totally satisfied so far with the car. I knew it'd have
some issues buying used so I wasn't shocked.
Old Mar 26, 2012 | 02:58 PM
  #433
ronnie948's Avatar
ronnie948
Hi MiniRY-- Check this out before you buy
The warranty takes over when your factory warranty ends. You will only be covered for one more year and up to 100,000 miles.
I think someone at your dealership does not really know anything about the Extended Motorer Protection.
They provide 5,6,7 @100,000 miles and 7 @ 70,000 miles plans. XL does not cover CD player or Nav systems. XXL includes XL & covers these items.
None of these plans include a clutch replacement at all. Clutch and components are exempt.
And, Every time you need to use this extended warranty there is a $50.00 deductible on each repair.
Go to Mini USA and look at the complete information.
I'm willing to bet that this is just about the most expensive extended warranty in the whole wide world.
Old Mar 26, 2012 | 03:56 PM
  #434
drsimmons's Avatar
drsimmons
^^^So true. Plus, some of the other warranty programs offered (outside of Mini), you have to really watch and read all the small print.
That's why I opted to go without and take my chances. I always stick a
little extra cash away for those rainy days .
Also, heard some horror stories about outside warranty programs being a
crock of poo poo.
Old Mar 26, 2012 | 04:08 PM
  #435
MiniRy's Avatar
MiniRy
Thanks for the feedback. I even asked him the guy at my dealer twice when I as on the phone and he said it is an additional 5 years. Seems like a mute point anyway... $3300 is just too much. I would never consider a 3rd party warranty anyway, I don't trust 'em. I am one of those guys when you buy stuff like a Best Buy, Target, etc. and they ask if you want the extended warranty, I AWLAYS say "no"
Old Mar 26, 2012 | 04:17 PM
  #436
slimjimtell's Avatar
slimjimtell
+1 2010 clubman S.
Complete timing chain, tensioner and other stuff replaced @ 37,000
Seems a little pre mature for this type of repair.
Old Mar 26, 2012 | 10:07 PM
  #437
Benibiker's Avatar
Benibiker
Originally Posted by slimjimtell
+1 2010 clubman S.
Mine only had 23,500 when it was replaced. I wonder if 2012s have the same problem? Anyone with a 2012 had it done?
Old Mar 27, 2012 | 06:32 AM
  #438
Gil-galad's Avatar
Gil-galad
I keep a fairly close and regular eye on the boards (NAM, MA, MINI2, etc.) and have yet to see a credible report of the associated "death rattle" issue related to the chair tensioner occurring in the N18 engine. This includes model years '11 and '12 with the LCI refresh.
Old Mar 27, 2012 | 06:50 AM
  #439
ronnie948's Avatar
ronnie948
Late 2011 &all 2012 _Problem corrected
From what I have read is that BMW changed the supplier of the timing chain components and the problem is totally gone after being replaced.They did have two suppliers for these parts so that is why some cars have problems and some don't.
It was not deemed a safety issue so no recall was called for. My opinion is it was and is a safety issue and they should recall and replace all of the chain tensioner cars involved.
How would you like to be in a bad neighborhood and have your engine fail? How would you like to be on Mini takes the states and have this problem. Breaking down anyplace is a problem. It should never be allowed to happen.
*********Darn right it's a safety issue.************************
I'm lucky because I have a very good dealer that cares about their customers and they took care of my tensioner /chain problems. But, there are some dealers that don't want to do warranty work and only want to sell cars. Then, There are the thousands of Mini owners that don't use these forums and do not even know a problem exists.
The big shots running BMW/Mini are pretty slick on some things like not including the clutch coverage in the extended motorer protection. They know there is a problem so why cover it under an extended warranty.
I'm not saying that if they remove the clutch and find it all burnt up from someone riding it they should pay. I'm saying that if the throwout crap bearing they use fails it should be covered.
Last edited by ronnie948; Mar 27, 2012 at 10:29 AM. Reason: Spelling & add information
Old Mar 27, 2012 | 07:11 AM
  #440
drsimmons's Avatar
drsimmons
Ronnie948 - very well put. Safety issue. I totally agree.
Old Mar 27, 2012 | 08:05 AM
  #441
jcauseyfd's Avatar
jcauseyfd
I've never seen a report where the timing chain tensioner caused the motor to stop while the car was in motion creating a safety issue.
I would have thought the chain tensioners might be a part where they would extend the warranty period ala the HPFPs.
Old Mar 27, 2012 | 10:38 AM
  #442
LaserblueS's Avatar
LaserblueS
+1 2009 Clubman S
Only 16k miles when brought in for Aux Water Pump recall. Told them it sounded like a diesel (always did). Work order said that SM 11 02 07 did not apply as production date is July 09, but chain was stretched to 68mm, top guid broken. New timing chain kit installed.
Took it home and it still sounded like a diesel. It's back at Dealer and MAF was found to be defective. Will get it back this week. I guess incorrect fuel / air mix would cause it to sound like diesel.
Old Mar 27, 2012 | 10:40 AM
  #443
ronnie948's Avatar
ronnie948
If the timing chain fails the engine won't run.
It won't hurt the engine but it will cause the engine not to run. I'm sure happy to have mine replaced with the newer parts.
When it comes to engines ""TIMING IS EVERYTHING"" Car will run bad or not at all with improper timing.
The fuel pump issue was handled great, BMW should do the same for the tensioner/chain issue. It would ease people's minds knowing that if the tensioner/chain fails when the car runs out of warranty it will be repaired.
It's not like these are inexpensive cars, They are a premium price and should really not have these problems to start with.
Old Mar 27, 2012 | 10:46 AM
  #444
drsimmons's Avatar
drsimmons
Ronnie, if the timing chain fails I was under the impression that
it could cause total engine disaster. Broken gear teeth or part of
the plastic guide getting caught up in the motor, sucking valves, etc.
Old Mar 27, 2012 | 11:12 AM
  #445
ronnie948's Avatar
ronnie948
I was told no
It is not like the engines that used to use a timing belt that when it broke it destroyed the engine completely. (Remember the first NEON'S?) Last of the neon's used a chain like the Mini engines. Ford Escorts were notorious for the belt breaking and destroying the engine. All timing belts should be changed at 60,000 miles.
They now designed the engines to use the chain and a different system of actuating the valves. If the chain fails the valves will stay closed and the engine is not harmed.
Very rare indeed for the chain to break, The tensioner will start really squealing and make a lot of noise first. The chain will just get very loose. The engine will be very rough and if you keep going the valves will not open and no gas will get into the cylinders to fire.
You will be stuck along side of the road.
When you go to your dealer ask them to check the length of the chain. Tell them your car sounds like a diesel and you are worried that something is wrong. (That is if you are still under warranty) The main cause of the problem is that the chain actually stretches and the teeth have a hard time on the pully. The tensioner works fine but the only thing you can do with a stretched chain is replace it. (Ask any old Harley rider)
Old Mar 27, 2012 | 01:24 PM
  #446
Slave to Felines's Avatar
Slave to Felines
I believe this to be incorrect. If the chain "jumps time" (moves to another tooth on the sprocket), then you will have the valves controlled by that camshaft opening at the wrong time. If the time is wrong enough, the piston for that valve will smash into at least one pair of valves.
If the chain simply pops off, there is a reasonable chance that it will do so when at least one pair of valves is open. They will stay open, the pistons will continue to move. The result is a collision, and significant engine damage.
There is nothing magical about timing chains versus timing belts that mean there is no damage when a chain has problems.
Old Mar 27, 2012 | 05:01 PM
  #447
drsimmons's Avatar
drsimmons
I wasn't going to dispute (the not causing engine harm) statement until I talked with my mechanic and he also confirmed exactly what you stated.
Luckily I've had mine replaced w/o incidence.
Old Mar 30, 2012 | 08:12 PM
  #448
Tarheel27410's Avatar
Tarheel27410
Have a 2008 Clubman S with 30,000 miles (only 1,500 of them mine). It's a Mini Next program car, so I have anoter 18 months of warranty. Heard what I thought was a heat shield rattle, but all the chatter here led me to have the dealer check it out. After a cold start evaluation, the chain tensioner and gasket were replaced, no charge.
BUT what worries me. Tech report notes that "spec" on the timing chain is 62 mm stretch. Replacement is required at 68 mm. My timing chain measures 66.5 mm.
I have only 1.5 mm between me and potential failure or certain replacement.
1. How will I know when the timing chain stretches more?
2. If it is almost out of spec at 30,000 miles, how many more miles can I clock before I really start to worry? I'm covered through Sept. 2014, but I'd rather not have the engine chew itself up.
Old Mar 31, 2012 | 04:50 AM
  #449
drsimmons's Avatar
drsimmons
This is why I think some people have had the timing chain issue more than once. I don't understand why your dealership didn't replace the entire thing, guide, pulley, seals, chain, adjusting bolt, etc.
When mine developed the rattle and my SA confirmed it, they out right said they won't just replace a part of it, but the entire thing.
Replacing everything with no warranty runs around $1700. I didn't have any warranty but they only charged me $500 and submitted the rest to Mini as good will.
To ans. your question, the noise the timing chain makes will sound like rocks bouncing around in the upper left (facing car from outside) of the engine. Or as some describe it, a diesel sounding engine.
Old Apr 7, 2012 | 05:54 PM
  #450
klarios's Avatar
klarios
Timing Chain Tensioner
+1 2009 Mini Clubman. Repaired this issue during warranty period.
Originally Posted by gjn25
if you have had any issues with the anything to do with the timing chain tensioner that may or may not have had to be over hauled completely. please just put a +1 and your minis year in this thread. I'm currently trying to get an idea of how many people have had work done not just think it broken but had work done to fix your issue. I'm currently speaking with a lawyer about this issue trying to see if we can get a class action against BMW for not doing something to fix this witch is an ERROR from manufacturing!!! please I need your help so that all of us can win this together.
thank you
FYI I m not trying to make money off of this suet I m just trying to get all of use a fix that they should have done voluntarily by BMW or at least the same treatment the HP fuel pump extended warranty on fix do to failure.
again thanks to all please just keep this thread a count avoid tilling of story's
just a +1 and your year
Just wanted to add this is only a count you will not be part of the class action in any way for any info you give here unless you want to once everything is ready i will give out the info to contact the law office that is handling the case at that point many thanks to all who have already posted every +1 helps
and lastly (lol I keep editing this) sorry for my spelling and grammar on anything I post i have a learning disability and if spell check dose not get it I can't fix...
