P1688 code, how to check bypass valve?
Old Apr 25, 2011 | 06:34 PM
Mikey52's Avatar
Mikey52
My wife was accelerating out of the tolls today and the car started slowing down on its own. She pulled off and shut it down, restarted and drove the rest of the way home (~35 miles). I was able to drive it a couple miles to Autozone and it was way down in power (limp mode I suppose). The code was P1688 which I'm reading is most likely either a bad bypass valve or a bum crank pulley.
I found the detroit tuned instructions on how to get to the BPV but how does one know if it's bad? Also, any tips on checking the crank pulley? I'm assuming of the two I should be hoping it's the BPV...
Oh, car is an '05 MCS with about 70k.
Old Apr 25, 2011 | 07:31 PM
S-thing's Avatar
S-thing
When my BPV died it would stick open. You can reach down below the inter-cooler and move the arm that connects the valve arm to the vacuum actuator. When mine got stuck I could tap the arm it would "snap" shut. Then I moved the arm and feel friction near the end of travel.
I installed a DT BPV and it fixed the problem.
Minimania has a pretty good picture of the arm at (DT shows the opposite side...):
http://new.minimania.com/web/Item/NME7609/InvDetail.cfm
-Jim
Old Apr 27, 2011 | 03:03 AM
Mikey52's Avatar
Mikey52
Thanks, so in that picture the arm is on the lower right? Which way does it move?
Old Apr 28, 2011 | 07:38 AM
S-thing's Avatar
S-thing
Hi Mike,
You are correct, the actuator arm is on the lower right. The black arm moves in and out.
Jim
wkp1219
Nov 13, 2015 07:52 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
massmini03
Aug 12, 2015 11:19 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
quickquest88
Aug 8, 2015 08:45 PM
