Sound while turning at low speeds
Old Apr 11, 2011 | 07:36 AM
evilness's Avatar
evilness
I've been hearing some noise coming from the front driver side wheel area when I turn sharply right at slow speed (1-15mph). The best way to describe the sound "Who-ooo-ooo" no clicking or grinding. This doesn't happen when I turn left at all.
I've researched the forums but coudln't find anything else relating to sound while turning a part from the clicking sound, my car doesn't have this. Here's my car specs: 2006, MC with 45 000 miles on it.
Any help would be great since I'm baffled as to what it may be, I was thinking bad CV joint or Ball bearing
Old Apr 12, 2011 | 05:39 AM
evilness's Avatar
evilness
Nobody else has this issue?!?
Old Apr 14, 2011 | 10:49 AM
rgc0233's Avatar
rgc0233
I don't have this problem with my MCS, but have a similar issue with my rwd 735i. It makes a low pitched 'whoomp - whoomp' while turning at low speeds. Suggestions have been possibly a dry CV joint.
Old Apr 20, 2011 | 04:22 PM
perucho's Avatar
perucho
Power steering pump whine?
Old Apr 20, 2011 | 04:54 PM
HRM's Avatar
HRM
Wheel bearing sounds get louder when turning. If you turn right, my guess is it is the left bearing since that pulls the wheel away from the bearing. You should be able to tell what side it is on with the windows open.
Old Apr 20, 2011 | 05:21 PM
Tomas_siba's Avatar
Tomas_siba
check your power steering fluid
Old Apr 25, 2011 | 09:13 AM
evilness's Avatar
evilness
Power steering fluid is topped up, nah it's not the normal whine it's actually another sound.
It's the front left driver side that generates the sound. My friend stood outside and didn't hear anything at all while I did from inside. Wierd part, I jacked up the car and tried to wiggle the tire, no play what so ever...
Keep in mind it only does the sound when I am turning right at a 90 degree turn or from a complete stop going right. A part from that, I get no sound, no shaking at any speed.
silence2-38554
Nov 12, 2015 09:39 AM
David.R53
Sep 1, 2015 06:51 PM
David.R53
Sep 1, 2015 06:49 PM
xpunisherx
Aug 10, 2015 10:50 PM
