Help!!!!! OBD2 issues
Old Mar 31, 2011 | 07:39 PM
BlueR53Terror's Avatar
BlueR53Terror
Im having a major issue with the check engine light turning on with code p1477, the even bigger issue is I have to take the car to the state emissions check. I know if I have a code present it will fail, I need to pass it be able to renew my plates. Ive search online to see what this code is and came out with 1. [SIZE=2]P1477 Leakage Diagnostic Pump Reed Switch Did Not Open What in the world is this???? I need to get this repaired and take the car to pass the emissions test. I've taken it to the mini dealer in the past but all they did way reset the cel for me, didnt really have a solution for me. If theres something that need to be replace I can handle it, I just dont know what this code is any help?
[/SIZE]
Old Mar 31, 2011 | 09:10 PM
k-huevo's Avatar
k-huevo
The pump is relatively simple to replace, place the car on stands, remove the right rear wheel and wheel liner to access. Some discussion on the subject https://www.northamericanmotoring.co...mped-tube.html
If you do a NAM search with the words, leak diagnostic pump, more info is available.
battlehawk_mini
Mar 5, 2021 06:15 AM
rtk90
Aug 29, 2019 09:08 AM
randeez
Sep 15, 2015 09:16 AM
Mini Koopa
R55 :: Clubman Talk (2008+)
Sep 8, 2015 02:58 PM
tylewis
Sep 6, 2015 01:07 PM
