What sensor is this?
Old Mar 30, 2011 | 06:38 PM
Philip Rushing's Avatar
Philip Rushing
I do not have a picture, but it is attached to the lower front of the block, directly beneath the waterpump port where it goes into the engine. (Directly to the right of the dipstick mounting bolt. My engine is greasy as hell around there, and while I have the engine exposed I would like to replace the seal if I need to.
I am replacing the water pump right now, and I noticed a little leak around the seal where the pump goes into the block and found the O-ring inside the facing was all cracked up.
Old Mar 31, 2011 | 06:44 AM
jhiggs26's Avatar
jhiggs26
Photo shows 1 of the 2 water pump/block flange o-rings. If the new pump didn't come with a new o-ring get another and replace both. The sensor you are asking about is the crank position sensor. There is an o-ring there and another on dipstick tube.
Inspect your thermostat housing for weeping/leaks while you are doing this job too.
Jeremy
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
sempaipaul
Sep 18, 2015 03:05 PM
Doc Pain
Sep 15, 2015 11:31 PM
Sep 14, 2015 12:48 PM
