Where to get new valve cover?
Old Mar 13, 2011 | 04:00 PM
JackVM's Avatar
JackVM
Ok, I'm a dork. I didn't read the directions on the new MSD ignition instructions and ended up cracking the plastic valve cover when I installed the
new coil. Now I have oil spewing out onto the header. Anyone have a source where I can get a used cover or replacement one other than a dealer?
I just checked and the crack doesn't go to any edges. It runs vertical for about two inches. Any thoughts on sealing from inside with strong epoxy?
Old Mar 13, 2011 | 04:40 PM
HRM's Avatar
HRM
People have repaired them, you have to search. As for buying one, this is a junk yard part to me, either local or online. WayMotorWorks probably has them.
Old Mar 13, 2011 | 05:10 PM
MI MINI S's Avatar
MI MINI S
JB Weld might be able to patch your valve cover. That stuff has repaired/fixed many problems for me.
http://jbweld.net/products/jbweld.php
Old Mar 13, 2011 | 06:51 PM
Vollgas's Avatar
Vollgas
Next time you try to install coil, put some silicone seal on each rubber washer to hold them in place. Must use the rubber washers/spacers.
There is a Mini salvage yard in CA called MiniWorld.
There is a thead about them in forum.
Ed probally has a VC.
Prices range $50 - 100.00
schwac2
Sep 11, 2015 11:13 AM
fireofficer001
Sep 1, 2015 09:49 AM
PaulWalliDumali
Aug 21, 2015 04:46 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
