Oil Leak! Please help
Old Mar 9, 2011 | 01:15 PM
Alexdrod's Avatar
Alexdrod
Hey guys,
I noticed oil leaking in my engine. It appears to be coming from the area that I circled in these pictures. Any ideas how to fix this? Hopefully this is nothing serious.
Thank you so much for your help.
http://imgur.com/bddCv.jpg
http://imgur.com/XNAD8.jpg
Old Mar 9, 2011 | 01:49 PM
stevendoll's Avatar
stevendoll
valve cover gasket?
Old Mar 9, 2011 | 01:50 PM
Alexdrod's Avatar
Alexdrod
I honestly have no idea. Is the metal thing hanging down the gasket? The "fresh" oil seems to be dripping from there.
Old Mar 9, 2011 | 02:34 PM
JAB 67's Avatar
JAB 67
The boots on the horns of the intercooler are likely loose. Take off the intercooler cover and its an easy repair, but needs a torx driver.
Old Mar 9, 2011 | 11:54 PM
Alexdrod's Avatar
Alexdrod
Is there a write up on this I can read online?
Kind of inexperienced and want to do things proper.
Old Mar 10, 2011 | 04:11 AM
JAB 67's Avatar
JAB 67
It doesn't really require a write-up. Get a torx driver - 25 or 27 I think - and remove the plate that covers the intercooler. Beneath that cover you will see that on either side of the intercooler there are flexible rubber boots that connect the intercooler to the 'horns' that mount to the supercharger, and to the intake manifold. The torx bolts that secure those rubber boots get loose, allowing the oily fuel-air mixture circulating therein, to leak out. Really quite simple.
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
