2006 mcs door hinges sound terrible
Old Feb 27, 2011 | 01:40 PM
bvgreek's Avatar
bvgreek
Has anyone experienced the door hinges sounding bad even after a fresh lube treatment=? My 2006 mcs sounds like the doors are almost binding. I've used everything under the sun for lubrication. I'm open to any solutions. Thanks Brad Augusta,Ga
Old Feb 27, 2011 | 08:58 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Hmmm, both my previous MCS and current GP's doors sound like a Rolls-Royce door closing. Any previous body damage?
Old Feb 27, 2011 | 09:12 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by bvgreek
Has anyone experienced the door hinges sounding bad even after a fresh lube treatment...I've used everything under the sun for lubrication. I'm open to any solutions....
I use a lot of WD40 until the noise goes away and then Triflow to try to keep it smooth and quiet. And then a dab of Lithium grease on the parts you see just to be sure. You can't over lubricate these hinges.
Also, don't forget the boot hinges as those are known to fail if not lubricated regularly.
Rich
Old Feb 28, 2011 | 06:53 AM
jbobp's Avatar
jbobp
I had the same problem on my'10. But, the hinge was lose where it attaches to the frame. Make sure the bolts are tight.
Old Feb 28, 2011 | 11:35 AM
Mini for life!'s Avatar
Mini for life!
my 06' MCS has the same thing ima get some grease and slap some on. that'll do the trick.
Old Feb 28, 2011 | 12:57 PM
quikmni's Avatar
quikmni
My 06 doors did the same thing. I used white lithium grease to lube them. All is good after the lube.
Steeroidz
Aug 29, 2018 07:41 AM
mrjolliff
Oct 9, 2015 05:55 AM
keck.j
Aug 18, 2015 08:18 PM
Powershift
Aug 16, 2015 05:14 PM
minipopkart
Aug 13, 2015 05:22 AM
