Noisy first gear and reverse
Hey guys I have an '02 S with a manual transmission and lately I've noticed that almost every time I start in first gear or put it into reverse and move the car, I hear this squeal. It only happens in those two gears, and its only for a little bit until I reach a good match between how far the clutch is out and the rpms of the engine. Ive been trying to keep track of where it doesn't make noise but I havn't been able to establish a pattern. The squeal is a sustanded sound with a pitch lower than that of a something like a fly wheal would sound like. Has anyone else experienced this or has any idea of what this is?
Good luck on the fix buddy!
Well calvin I am no Mini expert, but on almost all vehicles you have to pull the transmission. The release bearing is on the pilot shaft between the engine, and transmission. You will most likely have to pull the entire engine and transaxel to replace it!
Before you do that, I would see if there is a grease zerk on it, doubtful but it's worth a shot. Most late model release bearings are sealed bearings with no way to grease them.
I hope I am wrong, but it sounds likely that it is your release bearing!
RRWFREEDOM
R58 :: Coupé Talk (2012+)
20
Apr 26, 2016 12:56 PM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Sc00terbum
Sep 11, 2015 07:17 AM
