Wastegate issues anyone?
Old Jan 25, 2011 | 01:12 PM
  #51
OPC's Avatar
OPC
RATTUS Deserticus
FYI. Some graphical assistance:
Old Jan 25, 2011 | 01:24 PM
  #52
Stealth 993's Avatar
Stealth 993
Originally Posted by Bigprfed22
What management systems? I have also tuned many cars and motorcycles and dependant on management will get different scales of read outs.
BMW Bosh, Audi Bosh, VW, Mitsubishi, MAXX, MoTec, MegaSquirt, and several piggy back systems.
I used to run a local "Speed Shop" that specialized in VW, Audi & Porsche. While not the "best" tuner out there, I can hold my own.
Old Jan 25, 2011 | 01:34 PM
  #53
etalj's Avatar
etalj
Originally Posted by joshknot
Man am I happy I found this thread. I've had the canned RMW tune installed on my S since it first became available, and while Jan was able to smooth out most of the rough edges that were issues during my first few tune files, it's never been a smooth and happy relationship. All of the problems people are calling out in this thread I've dealt with for as long as I've had the tune- the hesitation, the boost cut, the unpredictable throttle response...but most recently I started noticing a flutter when getting onto the highway or accelerating up large steep inclines. It's really irritating, honestly, as it's not consistent whatsoever. As soon as I hear it, I can't replicate it no matter what gear I hit or how I manage the throttle, but I want it fixed.
Most recently, I was getting on the highway and experienced the surge/flutter and happened to have my eyes in the rear view, and for the first time I noticed the puff of smoke that coughed out alongside the flutter.
Now, my car's getting up there in miles at this point compared to a lot of the 2008s people are running on this forum (~60K), and I'm game to giving the WMW diverter valve a shot, and I'll even admit it's probably time to swap out my plugs. In the meantime, however, while I hem and haw about what exactly I want to do, I want to at least encourage you guys to keep posting as you chase down these issues. You're doing me a great service just by exploring the issues that I simply can't tackle on my own (limited time, mechanical ability, blah). So thanks.
Don't worry, I'll be chasing down this issue until I either fix it, or I die.
I checked the car yesterday for boost leaks via a smoke test, didn't find anything. Changed out the spark plugs with my brother's newer JCW, no change. The only thing I can think of that's causing the problem (and it scares me to say it, as I have no warranty) is the high pressure fuel pump.
BTW, the codes that I'm getting are: superknock on cylinders 1 and 2 (and on cyl 4 every now and again).
Old Jan 25, 2011 | 01:36 PM
  #54
Bigprfed22's Avatar
Bigprfed22
Just saying scales are different, dependant on software
I want to get my ghands on the dimsport Master tool
Old Jan 25, 2011 | 06:54 PM
  #55
Eddie07S's Avatar
Eddie07S
OK, that explains it, I just don't understand why you subtract 1-bar. Now I feel dumb. I still have never known to subtract from a MAP sensor. It should be calibrated for our cars, & should read 0 with the car on, but not running? Have you checked what it reads with the engine off? That to me would be what you should subtract.
My guess is you are running well over 5psi. 5psi is what aftermarket turbo system run on a high compression engine. Their is NO WAY you are making max HP on 5psi.
Mine (vacuum boost gauge) runs well over 5psi on application of 50% or more throttle. 1st gear does limit my boost.
Smart ***!
FWIW, it's 14.7psi
But changes with altitude, temperature, & humidity.
I still don't fully understand subtracting 1-bar, unless our MAP si calibrated to 1-bar with the engine off.
"MAP stands for Manifold Absolute Pressure. This means that the sensor measures pressure referenced to absolute vacuum, not atmospheric pressure like many vacuum and boost gauges. Engine parameters like fueling, ignition timing, compressor efficiency and so on are dependent on the MASS of air (in pounds per cubic foot or kg per cubic meter) entering the engine. As air is a gas, it’s mass is dependent on it’s ABSOLUTE pressure, referenced to absolute vaccuum and it’s temperature."
Here is another read on MAPs
http://www.autoshop101.com/forms/h35.pdf
I'm not saying your wrong, or that I am right. I'm just trying to under stand this. I have tuned a few MAP based cars, & few of them were forced induction, & we have never subtracted from the MAP.
You posed an interesting question, so I went and looked at the scangage with the engine off. But unfortunately the computer is not reading anything when the engine is not running, so the Scangage is left with the last reading when the engine was running. But, with that said, according to the Scangage literature the gage should read 14.7 psi (minus any altidude difference) when the engine is off. When the engine is running at idle then the gage reads ~3 psi, which represents a vacuum. When it goes above ~15 psi, it represents boost. That is why I subtracted the 15 psi (rounding). As you said, all of the mass flow calculations are base on absolute pressure. Seems resonable that the computer is reading pressure that way and the scangage will read the same (not count any programing that you can do to change that).
As for my own car, you got me thinking about seeing how high the boost would go with a more agressive throttle. So I ran a little test and I saw 24+ psi and that was not even maxed out (needed to back off for a stop light ). That would be about 10 psi boost. I am sure it would be even higher if I could have run it a little longer.
Old Jan 26, 2011 | 07:07 AM
  #56
Bigprfed22's Avatar
Bigprfed22
1 bar is 14.5xxxxpsi , atmospheric pressure is 14.7xx psi, easiest way to read is to actually have a boost gauge. Who wants to do math when your having fun !?
Old Jan 27, 2011 | 08:04 PM
  #57
OPC's Avatar
OPC
RATTUS Deserticus
Rats! The ALTA spark plugs were a bust. The MINI surged horribly under high throttle. Very consistent mis-fire at 3800rpm. Going to swing by the dealer tomorrow and get some stock plugs.
Old Jan 27, 2011 | 09:12 PM
  #58
etalj's Avatar
etalj
So far I've changed the diverter valve and spark plugs, and done a seafoam-type treatment with subaru Upper Engine cleaner.
No difference. Brilliant
Old Jan 28, 2011 | 02:30 AM
  #59
czar's Avatar
czar
If you installed the Alta (Brisk) spark plugs, straight from their boxes, then you will encounter all the issues you mention above, the stock electrode gap is 0.9mm (35.4 thou) this is far too large for our engines, and MUST be reduced to 0.45mm (17.7 thou) approx.
This 0.45mm (17.7 thou) setting is an approximate base line guide setting only, each individual engine will respond differently to the electrode gap adjustment!
Old Jan 28, 2011 | 07:31 AM
  #60
OPC's Avatar
OPC
RATTUS Deserticus
I gapped them to 0.019-inch (right in the middle of the ALTA recommended band). Which was a pain in and of itself as most spark plug gages don't go this small. I had to pick up feeler gages to do this. I can try knocking it down another 2mil, but I'm looking at the OEM plugs I removed and am having trouble reconciling the difference in gap. The OEM plugs are closer to 25mil.
Old Jan 28, 2011 | 08:08 AM
  #61
czar's Avatar
czar
You can't compare the OEM stock spark plugs to the Brisk Silver MR12YS spark plugs, if you have gapped them correctly, you will have no issues whatsoever, with the Brisk Silver spark plugs, trust me.
However with all that said, and you have gapped them correctly, and NOT tapped/knocked the electrode to your desired measured setting, then it is possible, you have a bad set of plugs, so contact your supplier (Alta) and take up the issue with them.
Spark plugs are delicate, and can quite easily be damaged in shipping transit!
Old Jan 28, 2011 | 08:20 AM
  #62
OPC's Avatar
OPC
RATTUS Deserticus
I didn't tap them to close the gap, I placed a paper towel on my work bench and pressed on the electrode. Just got off the phone with ALTA. He said they had one other customer reporting a similar issue, it turned out his gap was too high, but claimed he'd gapped them properly. I'll pull the plugs and re-gap to double-check. He recommended setting them to the lower end, ~18mil.
Old Jan 28, 2011 | 08:45 AM
  #63
czar's Avatar
czar
If you set them to what I advise 0.45mm (17 thou) you will not have any issues whatsoever!
The way you have gapped your spark plugs is WRONG and should NEVER be done this way, this will give you inconsistent radius bends of the electrode tip, leading to inconsistent gaps, you must only ever set your electrode gap, by means of a spark plug setting tool, this will give consistent gap sizing, and complete control when adjusting the electrode, and NEVER EVER pry against the centre core of the spark plug, to open up the gap, again you MUST use the spark plug gap setting tool.
Old Jan 28, 2011 | 08:57 AM
  #64
OPC's Avatar
OPC
RATTUS Deserticus
I like your use of caps and text color. Very dramatic.
Fact is, I do realize the arc of the ground electrode could play into the performance of the plug. That said, I had few options for setting a gap this small. I'll see if I can find some gapping pliers - assuming this is what you're recommending since a google search results in at least 10 different methods and tools for gapping plugs (my approach included) and your post is pretty nebulous (pretty colors notwithstanding). Thanks for your advice, I do appreciate it.
Old Jan 28, 2011 | 05:40 PM
  #65
ThumperMCS's Avatar
ThumperMCS
They extended the warranty on HPFP's to 6yr/120k....not sure if that's just in North America though.....
Old Jan 28, 2011 | 06:13 PM
  #66
Eddie07S's Avatar
Eddie07S
Just FYI - But, part of the function of the direct fuel injection used on the 07s and beyond is to cool the cylinder and piston to prevent knock. In the old days you could not run a turbo with 11:1 compression ratio, as the Mini does, without destroying it very quickly. Most turbo engines back in the day ran less than 8:1 which made them whimps around town.
So, not saying it is, but you could be onto something with the fuel pump and all the knock you are getting. Sorry but they are known to go bad (mine has been replaced).
Old Apr 21, 2012 | 08:29 PM
  #67
lukwen's Avatar
lukwen
Check Power Available
I also had a knocking issue with my 2008 mini cooper mellow yellow S. It can be traced to alot of different issues. I like to get right in there. Being that the alternator is located so closely to the cat alot of heat is generated. I went ahead with the replacement of that to ensure that it had all the power I could get. Then I change the spark plugs ngk ix's. then I replaced all the coil packs from bavarian as needed to begin with Its a interesting issue with the coil packs. Every time you wash your car at a automatic car wash you stand the risk of getting the packs soiled then they rust on the sleeves I had three of the four packs with rust on them I replaced the the car had no knocking what so ever. This was also done with a ALTERNATOR REPLACEMENT EVEN THOUGH IT IS A 2008($$$$). but now it runs fine in that respect with the knocking issue. I have alot of old mechinec knowlege dad owned a porshe audi shop in the 70's I know how to use a 2 inch circle mirror if anything else. What I am getting at is that alternator and the trouble codes that i had(according to the bavarian tech software obd2 type stuff)was saying that I had low power along with this knocking issue in different sectors of the electrical system. This low power issue causing things to not quite work weather it be because of a off top dead center type of start on a hill in a hot parking lot type of thing. IS STILL A LOW POWER ISSUE JUST BECAUSE THE CODE CAME UP ONCE AND NEVER OCCURED AGAIN DOES NOT MEAN THERE WAS NO REASON FOR A LOW POWER POSSIBILITY WITH OTHER SUGGESTIONS OF WHAT THE ANSWER MIGHT BE WHEN i read the software code answers. answer Alternator.
battlehawk_mini
Mar 5, 2021 06:15 AM
rtk90
Aug 29, 2019 09:08 AM
Mini Koopa
R55 :: Clubman Talk (2008+)
Sep 8, 2015 02:58 PM
tylewis
Sep 6, 2015 01:07 PM
WestfaliaR
Aug 19, 2015 08:01 AM
