Cruise control
Old Dec 23, 2010 | 10:49 AM
TylerF's Avatar
TylerF
Cruise control
What does it mean when I try to set my cruise control, but the light on the tach just blinks 3 times then goes out. It won't let me set it. It worked yesterday...
Old Dec 23, 2010 | 12:09 PM
MINIdave's Avatar
MINIdave
I went thru this on my '03 MCS, first they replaced the brake lite switch (I'd check this first as it's easy and inexpensive to replace) then the clutch switch (ditto) then the steering angle sensor, then it finally turned out to be the ignition switch (just the electric part, not the key part)
So check the easy things first, the brake switch could be bad or just out of adjustment.
Old Dec 23, 2010 | 08:54 PM
TylerF's Avatar
TylerF
Hmm, I'll start checking those in the morning. Something I hadn't thought of before- It started right after I put in my PF transmission mount inserts (and had all the associated stuff unplugged, including the ecu). Could that have anything to do with it, do you think?
Seems weird that it'd be a coincidence that right after I unplugged that stuff, a sensor failed...
Old Dec 26, 2010 | 05:51 PM
IanF's Avatar
IanF
I hope it's something simple. We had a similar problem with our '03 MCS back in '04 or so. It took the dealer 6 attempts to finally fix it (under warranty). Darned near everything was replaced by the time they were done. But (knock wood), it's been fine since.
ryGuyMCS
Oct 6, 2015 12:04 PM
Suspension Products
Sep 10, 2015 11:46 AM
Norton70
Sep 7, 2015 05:06 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
