The Yo-Yo Chronicles
Originally Posted by tme
I'm coming up on my 10K mile service and I can't decide whether to get the upgrade to V38 or not. I had a terrible yoyo until I applied the cable tie fix, now I have NO yoyo, and better throttle response, and minor (if any) gas mileage reduction (of course I'll snip the ties before it gets to the dealer).I've read in a couple of places that V38 "fixed 99% of the yoyo" or "almost fixed the yoyo".... The cable tie fixes it 100%.
So I'm wondering, since I'm pretty happy with the cable tie fix. Why should I get the new SW? Is there a compelling reason to get V38, or not to get it?
As a corollary what if I get V38 and then re-apply the cable tie fix anyway?
Any thoughts on this would be appreciated.
And to MINIUSA please don't input your "lawyer post" about "modifications to the vehicle void the warranty"....
MINI really should hire someone to write some decent firmware...
the word incompetent comes to mind
The inconsistency in everyone's findings is bothersome; why is it that some cars have the "rough idle" with some software versions but not others, and others react differently? Is the "adaptive logic", too adaptive, or too sensitive?
V38 hasn't entirely eliminated the yo-yo, but now it's slight. Unless I really try for it in 3rd or 4th gear repeatedly, it doesn't bother me.
Cruise control is good, consistently +/- 1MPH. On very steep hills, occassionally -2MPH briefly.
Cold start is worse, tho
MTH software seems to have gotten rid of the yo-yo. At least to the point that I don't notice it at all.
I've read that UNIchip's mapping is very dense in the RPM range that the yo-yo occurs, and it seems that MTH's mapping is similar. I've driven two tank-fulls (about 500 miles) since the MTH software install, and have yet to notice the yo-yo. All I feel in that range is torque. And today I even drove very mild mannerdly. [maybe that's where the word "nerd" comes from]
Well I finally got my V38 upgrade, and the yoyo seems to be gone, so is the cruise control variability.... BUT now I have the rough idle problem!!!
I didn't make the connection with the software upgrade until I started snooping around here. What a bummer.
Thanks for the info.... I know I'm keeping my bypass valve tied up so all the air flows through the supercharger!!!!
Oh-no more yo-yo
Hi all,
I must admit I am a newbie at this, so if I repeating anyhthing already discussed please excuse my ignorance of not seeing it.
I am the new owner of a 04 MCS, I am to plagued with the infamous yoyo. My car originally had v36, but after 4 trips to the dealer they dropped in v38. I feel it actually made it worse, although the yo yo is not as high reving it is more frequent at idle. I of course took it back and they said they dropped in v38.1, but I think they are shooting me a line of " ".... I was also wondering if dropping a pulley on will make matters worse? And will putting on a pulley really shred the water pump and the sc as fast as some folks say....
Thanks for any input...
Yo-Yo is gone, but...
Took my '04CooperS to Assael Mini out here in Pasadena, CA for a second look at my short list of complaints: (1) engine knock; (2) yo-yo; (3) rough shifting trans from 1-2; (4) coolant loss; (5) squeal in window motor. They claimed the engine knock "is normal for '04CooperS models"
; they blew a new software revision v38.x in which appears to have eliminated the yo-yo, but the car idles roughly now and the overall performance seems less responsive; they replaced the entire trans; they put a new cap on the top of my coolant overflow bottle and replaced the driver's side window motor. I give Assael high marks for attentiveness, politeness and willingness to listen, although I do not buy the line about the engine knock. This issue I will have to escalate. In the time since I took the car back, the Mini seems to have developed a problem/noise in the A/C compressor and the entire climate control system went dead for no reason, but then comes back to life a couple of hours after sitting in the parking lot
. I believe this car will continue to be problematic (although just a blast to drive!)...I think it would be unwise to keep it a day beyond it's 3 year factory warranty.
should I???
I have a YO-YO free '02 MCS. I am currently on v.36. I still continue to have cold start problems on occasion. Should I have my dealer upgrade me?
What are the potential benefits of putting v.38 in an '02 MCS?
What are the potential drawbacks?
--->biggripper: When it comes to MINI factory software, the ole' saying comes into play "If it ain't broke, don't fix it." V38 won't help your cold-start, so if you're satisfied how it runs, don't mess with it.
Just turned 10K today
I am going in for my one year (exactly one year from when I picked up my car) service and have requested v38 be installed. I am hoping to rid my MCS of the yo-yo and cruise control +/- 4 mph issues. I will report back soon...
Cross your fingers, I would but it was too hard to keep typing. Hopefully I won't inherit the cold start issues or rough idle problems.
v38.1 installed today
My first service appointment went well. The service department did an excellent job patiently listening to my concerns and documenting all issues I have experienced in the past year (auto climate control did not turn on one time during the winter but worked after shutting the car off and turning it back on; my rear wiper stopped in mid-swipe two days ago and worked properly after turning the wiper off and then turning it back on; yo-yo issues; cruise control fluctuation; rattle from the boot area).
I am happy to report the cruise control was fixed (at least for now). Worked like a charm for 70+ miles after my appointment with maybe +/- 1 mph. I was impressed.
The yo-yo between 3-4K rpms appears to have been solved, too, with v38.1 (version my advisor verbally said and what is printed on my receipt). Didn't feel a thing during the ride home. Will update if any change occurs. I tried to get it to yo-yo but it wouldn't, thank goodness. Feels so much smoother with no rough idle or cold start issues. However, I only started my car twice since the update. I was stuck in rush hour traffic in Indy with no rough idling.
The rattle in the rear boot was stopped with the installation of a thicker striker. Apparently the striker on my car allowed some movement of the hatch. If you have a rattle, the dealer will fix - at least mine did without any hestitation.
Asked about the operation of rain sensing wipers. If it is raining and I turn the car off with the switch still set to auto mode and then get back in, for the auto wipers to work I have to turn them off and back on for the auto mode. Not so auto in my opinion. Anyone else with this issue? The dealer documented, 'advise customer that this is normal operation - must be reset each time ignition is turned off.' Comments please.
Also asked about programmable options. The dealer did not have a list but called me with a list of 5 options. They said with the v38.1 only 5 options are available. I wanted to program the central locking toggle switch to open the sunroof and windows if held in the up position. Apparently, this is not an option. Any comments?
Overall, quite satisfied with the outcome of my visit. However, one odd thing happened. I asked the dealer not to test drive my car and made it clear to them this was not negociable. I dropped my car off with 10140 miles on the odometer. When I picked up my car, it showed 10138 miles. How in the hell did my car lose 2 miles???? Quite odd and a little suspicious. Trip odometer only showed .1 mile (reset it when I dropped it off). Computer malfunction? Drove it around in reverse? I have no idea.
Steven
Steven
I think when they program the ECU, they have to type in the mileage manually. I lost over 80 miles the last time my car was in for ECU issues, I was in for back to back visits (only a day apart), and I believe they used the mileage from the previous day and not for the current day I brought the car in.
Steven
Originally Posted by mattcoon
This is standard. I thought it wierd at first,too, but after asking other people with this option on other makes, this seems to be typical of this feature.
Loss of mileage
I have had my car reprogrammed 4 times by the dealer and I always lose a couple of miles here and there. I just got used to it, I look at it this way it is just 1 or 2 more I can drive to catch up..... lol
V.38 comment
Just brought my MINI in for it's first unscheduled service, and although the manager seemed to know exactly what was causing the boot rattle I've developed over the past few months, the thicker striker did nothing.
Although this result is a bit disappointing (especially since I'd already tried the electrical tape fix others have suggested, and quite honestly, I don't think they really tried to find the source of the problem), the service manager at MoP was very positive, and said they'd find and fix the problem. Has anyone else noted any other sources of noise in the boot area (particular in the Left rear side) ??
I know this does not pertain directly to the Yo-Yo problem specifically, but while having my boot rattle looked at, I overheard someone speaking about the V.38 software upgrade, and it seemed they had no improvement with this upgrade. I know this has been mentioned before, but I just thought I'd add another data point.
BB
BB
If your rain sensing wipers happened to get frozen to the windshield over night, would it not tear the hell out of things if the wipers tried to start automatically when you started the car up next morning?
quite strange indeed!
